Playing around with inj timing--Is there a rule of thumb for boosted cams (little overlap)? Been using stock j141 of 300^ across the board and likely blowing too much fuel out (false lean condition but getting ++fuel smells). Searching pointed that non-boosted setups should have timing before intake opening to get some atomization unless you have big overlap. My cam is a custom for boost (224/230 .548/.548, 114), Cam Analyzer says intake opens 334^ @0.006, exhaust closes 374^ @0.006. EA has 356^/357^ (1^ overlap matches cam card). Should I just go with when the exhaust closes so I don't have boost blow out fuel whatsoever?
Can't use EA to calc since I'm logging via TunerProRT (tried converting the csv and redoing the column labels, but didn't work).
recharged95
Users browsing this forum: No registered users and 65 guests
