- 89ragtopgt
Transmission load type ? what value here
Ok i have been playing around and was logging the car with the factory a9l bin loaded in and i was watching the timing.. it was super stable and did not change at idle responded very well with the throttle. it seems to idle higher that the value set in the scaler. The setting in that scaler is 3. Now i have been tuning the car with that value set to 0 and then the timing varies and is not that stable 17-21deg. the idle is lower and very close to the one i set in the scaler. could someone pleae verify by changing the value in your scaler and let me know what happens? or if someone can explain what these settings do. It seems to do a lot for such a simple item and there is not a lot of info on this item.
306, powerdyne(gone)(novi 1000 sold) novi 2000 Out of fuel@5000rpm. 8" crank pulley, Moates Quaterhorse, SVT heads, kb pistons, Anderson B21 Cam, trick flow intake, 60lb inj, sct ba2800, long tubes, x pipe, 70mm tb, C.F clutch 355 gears, 1.7 roller rockers, A9L
- Jack Hidley
- 89ragtopgt
- 89ragtopgt
ok is this it
TRLOAD = Transmission Load.
0 = Manual Transmission, no clutch or gerar switches,
forced neutral state (NDSFLG = 0).
1 = Manual Transmission, no clutch or gear switch.
2 = Manual Transmission, one clutch or gear switch.
3 = Manual Transmission, both clutch and gear switches.
4 = Auto Transmission, non-electronic, neutral drive switch.
5 = Auto Transmission, non-electronic, neutral pressure switch,
(AXOD).
6 = Auto Transmission, electronic, PRNDL sensor - park, reverse,
neutral, overdrive, manual 1, manual 2.
ok what do these inputs do to the eec .... does it add timing and or rpm bases on these switches? i think mine are disconnected. should i reinstall these for proper operation?
(AXOD).
rockin_rick
http://www.tweecer.com/downloads.htm89ragtopgt wrote:where is this available for download?
called GFUB.zip
Rick
- 89ragtopgt
ok now there is also transmission strategy as well. these scalars are both activated by opening or closing a switch. it make some sense that on the clutch linkage there is 2 connections for the 2 switches. so when connected and you push the clutch in it must make or break the connection and then the motor idles up a bit to prevent stalls in conjunction with the vss sensor? I guess one way is to connect both switches up and try unpluging one at a time to see how it reacts.
Users browsing this forum: No registered users and 176 guests
