mach1
No VSS No Problem?
Post by mach1 » Sun Dec 04, 2005 4:49 am
I just dropped a Turbo 400 in my car and I no longer have a VSS, car is running horrible and I am curious as to if this has anything to do with it. I did a few other things while the motor was out (just a freshen up) but it will run fine until it changes from the defaults and starts pulling values from the sensors then it falls on its face. It will usually run pretty good until I get into boost then get out of it then it just gets mega loaded up ~10:1 AFR and eventually dies from getting flooded. Car is a 95 Cobra, F-Cam, T70, 42 lb injectors, 90mm LMAF (draw), Turbo 400 with a 4400 stall converter. Any suggestions would be great!
Users browsing this forum: No registered users and 131 guests
