JONESGT
Sealevel Load Scaling Vs. RPM for SC
Post by JONESGT » Mon Feb 06, 2006 10:49 pm
Does anyone have any suggestions on what values I should use for the values in the Sealevel Load Scaling Vs. Rpm Function for my setup. I know the entire load curve needs to be scaled up due to the increased loads seen from the SC. Just not sure how much.
87 GT, A9L, 306CI, 85 mm C&L Tuner MAF, 75 mm Throttle Body, GT40 Intake, Trick Flow Heads, 42 lb Inj, Procharger P1SC w/ 3 Core Sheet Metal Intercooler, 9lbs Boost
Shaker666
Post by Shaker666 » Tue Feb 07, 2006 12:53 am
This function should represent the revised volumetric efficiency of your engine. Sorry, my curve is for a twin screw blower, though. It would probably really screw your tune up. Perhaps someone with a similar combo's will work better.
JONESGT
Post by JONESGT » Wed Feb 08, 2006 9:15 am
Yea that is kinda what I was hoping for when I wrote this post. I would think that there is sombody out there that has a Procharger SC1 on a 306 CI engine.
gt90stang
Post by gt90stang » Wed Feb 08, 2006 3:28 pm
Someone I know with a 9psi SC 306 setup uses:
0.2, 0.3, 0.5, 0.7, 0.9. 1.1, 1.3 and 1.5 for load scaling on an A9L.
YMMV, Don
JONESGT
Post by JONESGT » Wed Feb 08, 2006 8:50 pm
Hey, thanks for the response and the info. I'll give those numbers a try.
pthornton
Post by pthornton » Wed Feb 08, 2006 9:13 pm
You can also run EEC Analyzer against your datalogs and fine tune it to your exact setup.
Cobra Intake / AFR 165 Heads
CompCams 270H Camshaft
1989 Saleen Coupe # 653 *****
po-po 5.0
Post by po-po 5.0 » Thu Feb 09, 2006 9:30 am
pthornton wrote:You can also run EEC Analyzer against your datalogs and fine tune it to your exact setup.
I second this. EA is how I calculated that data on my procharged 5.0. I seem to remember mine scaling up past 150% though.
'00 Lightning: factory tech valve body, 6# lower, EGR delete, catback. ported blower
Users browsing this forum: Bing [Bot] and 191 guests
