jopes
Tuning problems
Post by jopes » Tue Feb 28, 2006 3:38 pm
See my sig for specs.
-fuel pressure is as close to 39 psi as I could get it with the vacuum plugged in.
-all sensors brand new except TPS
changed the following
-injector slopes, 30 and 38.5
-transmission stradegy to 1
-engine displacement to 408 ci
-injector breakpoint to .00002550 (what ever the tweecer manual said was for 30 lb injectors)
-Loaded the 90 MM LMAF transfer
-edited the cranking fuel pulse width vs ECT to reflect the 30 lb injectors.
-Changed the EGR scalar to reflect the EGR being removed.
-Also turned off the Thermicative solenoids and canister purge
My problem is it idles pretty smooth, but stumbles once and a while, once I touch the gas it starts popping in the exhaust and runs like crab. But if it is idling and I put it in the floor it revs up to 5000 rpms with out any hesistation. When I have it running it is putting out a pretty rich exhaust cloud.
Trying to drive it is nearly impossible unless I am slipping the clutch to keep reving the engine so it does not pop. Hopefully tonight I can do some data loging and see what EA tells me when I am done.
It runs the same when it is cold or warmed up to operating tempature.
I just feel like I am missing a setting someplace to get it running decent. I dumped the carb because I wheel this thing offroad alot and was wanting the EFI for smooth off camber running. Not looking for the last .001 second out of the quarter mile here. Just want it running good. :)
If I missed anything I will add it tonight when I get home.
78 bronco, 400, single plane intake machined for injectors, 30 lb, 90mm LMAF, 70mm throttle body, 89 stang harness, A9P ECC, removed everything unneccessary from harness. Tweecer R/T and ECC Analyzer.
pthornton
Post by pthornton » Tue Feb 28, 2006 9:13 pm
First off, set the fuel pressure to 39.5 with the vacuum disconnected.
Cobra Intake / AFR 165 Heads
CompCams 270H Camshaft
1989 Saleen Coupe # 653 *****
jopes
Post by jopes » Tue Feb 28, 2006 9:56 pm
so I was off a little in that part.
I just reset the FPR to 39.5 with the vacuum disconnected. it smoothed out the idle. but it is still popping when when you try to hold a RPM on it.
jopes
Post by jopes » Tue Feb 28, 2006 10:04 pm
it is running so rich you can see the cloud behind it. I dumped about a gallon of water all over the engine to see if I had any vacuum leaks and I could not find any.
I am flustrated and thats not helping any.
EFIpunk
Post by EFIpunk » Tue Feb 28, 2006 10:05 pm
i say your maf transfer is off...subtract 15% from 1.2volts & down
jopes
Post by jopes » Tue Feb 28, 2006 10:18 pm
EFIpunk wrote:i say your maf transfer is off...subtract 15% from 1.2volts & down
tried that, still the same.
any other ideas?
jopes
Post by jopes » Wed Mar 01, 2006 1:28 am
I was reading alot tonight in EA about cams. This is mine, Is there any problems running this cam with my setup?
http://www.supermotors.org/vehicles/reg ... original=1
86GT
BE/EA Developer
Post by 86GT » Wed Mar 01, 2006 2:42 am
The cam seems to be OK, what about your loadX at an idle. It should be around 25-30. If it is above 30 it will not go into Closed Loop.
jopes
Post by jopes » Wed Mar 01, 2006 3:18 pm
I am giving up for now. Made an appointment at the dyno tuner out here who is a tweecer dealer whom tunes with the tweecer. Couple hours of dyno time I should have a running engine again with a dyno sheet to boot. I am excited now. :D
Users browsing this forum: Bing [Bot] and 192 guests
