does anyone know enough about exhaust dynamics to say what affects very short systems might have on these readings?
my exhaust from manifold to atmoshere is about 30 inches long. on the previous engine as well as the present both carry black soot in the outlets. smells rich at least at idle. not always a steady idle. consistant 25mpg below 60mph and town driving. 2 inch bores on pipes and glasspacks duals. this is a 99 3.8 in a 1500#car.
now im thinking the sytem is so short there is absolutely no back pressure leading the sensors to say lean and cause it to run rich. also have read to work properly they need some back pressure, if so should i add some sort of restriction to the pipes?
any ideas out there
lets hear them
