Jamlx1
accuracy of hp/tq in EA
Post by Jamlx1 » Mon Nov 29, 2010 12:14 am
Was wondering if anyone may know how accurate the hp/tq tab is in EA.
92 Mustang LX- Wild Strawberry:
forged 306, twisted wedge heads, xe-270-hr-12 cam, 1.72 rockers, T5 Zbox, kennebell @ 10 psi with tmoss ported gt40, 1 5/8 bbk long tubes, X-pipe w/cats, mac catback, 3:55's, pmass velocity 95mm, anderson power pipe, 42lb injectors, 190 fuel pump
A9P with A9L GUFB, moates qh 1.6- binary editor and eec analyzer, xd-16 and lc-1
Re: accuracy of hp/tq in EA
Post by decipha » Mon Nov 29, 2010 1:19 am
not very
Chucko
Post by Chucko » Mon Nov 29, 2010 2:44 am
I've asked Clint if there was any way to not calculate these. I have no faith and no interest in the computed HP/torque numbers. They just get in the way IMHO.
Jamlx1
Post by Jamlx1 » Mon Nov 29, 2010 3:04 am
I was just courious if they were even close to go by or an over the top numbers.
Post by cgrey8 » Mon Nov 29, 2010 6:22 am
They are no closer than your input numbers. Most people need to be on a dyno to know what their actual BSFC is. EA assumes a BSFC unless you change the default value. But without knowing a round-about value you believe your engine is at OR testing it to find your actual BSFC, it's just guessing, so the output from the HP/Tq calcs will be equally as accurate.
dualdj1
Post by dualdj1 » Mon Nov 29, 2010 1:54 pm
There's a program called Desktop Dyno that's pretty good for estimating hp/tq, based on your engine components. But that's just theoretical, untuned, more of a guide really.
1978 Mustang II King Cobra
5 spd Manual
Post by decipha » Tue Nov 30, 2010 1:15 am
you can look at the mafv and infer that
what i do
