New look, fixed registration, new features coming soon...
As I am sure everyone can see, I have updated the look of the site. This is the new theme I developed for the new site, of which the new features are coming soon (within a couple weeks, more on these later).
I had heard the registration was broken and decided to go ahead and toss up the new design...let me know what you guys think...
Re: New look, fixed registration, new features coming soon..
We've already gotten a few spammers get through in just the past few hours. But after logging into the admin settings, I found that the update reset some registration stuff. No email verification was being required. The update also adds the option for a question to be answered during registration. To register, new users must read the Best Practices thread in order to get past one of the registration steps. So far with these new settings, no more spammers have gotten through.
BTW, thanks for looking into the registration issue. I've been manually adding people to the site.
- PoweredbyEECV
I like the new look.
98 SVT Cobra Convertible - Laser Red/Saddle/Saddle #2906 of 3480
BE - Version 2009 Build 39
Definition: CRAJ0
Binary file : AOL3
Tuning & Data Logging PC: Acer Aspire One Netbook, 1.60 GHz, 1.48 GB Ram - Windows XP HE SP3
TWEECER-RT with BE & EA Software, DataQ 148U for AFR & 3 bar MAP sensor, Wide Band Commander, KAM clearing switch.
Stock Engine w/: V1, S-Trim w/AC @ 10 PSI, 60 lbs injectors, T-Rex FP, FP set at 45 psi, no FMU. Custom CAI, IAT relocated, ProM-77 MAF. Scream'in Demon coil packs and Live Wires.
Definition: CRAJ0
Binary file : AOL3
lookin' good jon, it's nice to have a fresh new look for the new year a-coming.
i'm still checking out the new features but i likey thus far
Like the new look, looks more modern. Can't wait to hear about the updates. Was thinking it would be nice to have a shared area for tunes, data logs, and templates. Maybe a naturally aspirated forum, boosted, and a nitrous forum. Just a thought. Thanks for all the hard work. -Byrne331
92' LX, GUFB, A9L, Tweecer R/T, BE & EA, LC-1, 331, 10.5:1, AFR 185's (mild port work), Edelbrock RPM II (lots of port work), PRO-M 77mm (30 lbs cal), FRPP 30 lb/hr red top injectors, Accufab 75mm, 227/233 @ .050 .576"/.560" camshaft, 1 3/4" BBK LT's - Best E.T. 11.80's @ 118 untuned, prior to port work...
Like the old look better. It fit better on my smaller netbook screen. Seems to waste more space now.
Jon, if you can add the Prosilver and Subsilver (old default) looks back, but keep this one as the default, then people could choose which they prefer in their User Control Panel.85GT wrote:Like the old look better. It fit better on my smaller netbook screen. Seems to waste more space now.
Chris, yes...I am aware, however the issue is that the new features which are mostly complete would necessitate considerable modification (as well as maintenance) of the other styles...something I simply do not have the time (nor desire, honestly) to do/keep up with. i specifically removed the default themes that ship with phpbb because of this.cgrey8 wrote:Jon, if you can add the Prosilver and Subsilver (old default) looks back, but keep this one as the default, then people could choose which they prefer in their User Control Panel.85GT wrote:Like the old look better. It fit better on my smaller netbook screen. Seems to waste more space now.
Unfortunayely, for those reasons the default theme is now the only theme. The new features will make up for any annoyances the change has caused, I promise!
What kind of new features?
Right now, on a netbook, the View new posts line is in the middle of the screen. I only see the first 2 topics now. If you could loose the car and tighten up that banner that the car cuts through, that would help alot.
You can set your resolution to 1024 x 600 and you can see what I'm talking about.
dualdj1
Nice work Jon, thanks for keeping the site up to date!
Keep patient folks, things like this can be fixed/adjusted, but does take some trial and error. Just keep politely posting your issues and I'm sure Jon will be able to find an acceptable solution.
1978 Mustang II King Cobra
5 spd Manual
5 spd Manual
dualdj1
My suggestion would be: I do like the outside frame, however I'd shrink l/r margins to match the bottom margin, allowing the center frame to grow more. Hopefully that would not be problematic for the design.
5 spd Manual
5 spd Manual
Some more input, the search options section. The radio buttons don't coincide with the choice labels.
Some come out horizontal, some vertical, yet all labels are vertical.
At least on my netbook.
I love the new look. We need to look into re-installing the smiley packets or installing new ones all together. Keep up the great work Jon.
dualdj1
also did old avatars get broken? i see a lot of people with missing avatar pics. not a big deal, just an fyi
5 spd Manual
5 spd Manual
Users browsing this forum: Google [Bot] and 34 guests
