Share your dashboard
Anyone out there made up their own custom dashboard for Binary Editor? There were a couple in the FAQ,but the files are no longer available. Attach your dashboard file to this thread so we can all see what's out there.
1986 Merkur XR4Ti
2.3L turbo, crower 5.5" rods, Wiseco 8:1 pistons, ported/big valve head, gutted/ported intake, ported E6 manifold, T04e-44/T3 stgIII @ 21psi, NPR intercooler, Forge 004 BOV, T5 trans, PF3 ECU, VAM to SD conv. 3bar MAP, 55lb injectors, QH, BE, DataQ DI-148U, PLX SM-AFR
1992 Mustang 5.0L notch
stock shortblock, TTI single turbo 60-1 @ 14psi, GT40 irons, Crane 2031, Performer intake, 42lb injectors, A9L, QH, BE,LC-1
Re: Share your dashboard
This is what I use.
Elastique46
I can't see the file. :(
How do you not see it? I see it....
Updated 2/13/17
