Has anyone who can share done any work on the newer Spanish oak ECU's?
With the EEC they were all very similar, in that finding tables and functions ect. Not having any examples of table lookup routines makes it hard to make a start.
From looking at the bins it looks like the table values are 32bit wide and are massive in size.
For what its worth Ive got around the Mode27 security and can flash new calibrations into the ECU.
- 86GT
- BE/EA Developer
Re: Spanish Oak
Ask Adam Marrer. He has a few broken out that work with BE. There are parameters on the config tab of the strategies within BE that must be set. For Example PPC must be set to true. Also most all PPC (Power PCs Spanish Oak, Black Oak, Whatever Oak
) use a formula of "X" and the Bytes are set to -4 which indicates a floating point using 4 bytes. BE and the use of the Drew Tech Mongoose the Spanish Oaks can be logged. I am currently trying to get past Fords Seed/Key to be able to read and write to them.
