Cougar281
Hardware Specs
Post by Cougar281 » Mon Nov 21, 2011 1:06 am
Does anyone know of any resource to look up actual harware specs for variuos Ford PCMs, such as to be able to see the differences between a MPC-14D PCM used on the 04 Mach1's and Cobras, and the MPC-15B used in the GT's, both of which use the FBFG2 strategy?
1995 Mercury Cougar XR7 -
  • 2002 "Explorer" 4.6L V8
  • "Pink Top" F0TE-D9B Injectors
  • 2002 Mustang GT MAF
  • J-Modded 1999 Mustang GT 4R70W Trans
  • 22c Plugs
  • Cobra Radiator & Fan
  • 255LPH Fuel Pump
  • 180* T-Stat
  • 2004 Mustang GT PTP2 PCM
  • QH v1.6 & BE.
teal95
Re: Hardware Specs
Post by teal95 » Mon Nov 21, 2011 9:39 pm
I don't know of any spreadsheets or anything else that lists the changes. Since you already know the application for them you should be most of the way there. Another way of researching would be to go through the spreadsheet that is floating around and see what other applications use the same hardware code but I doubt that'll get you very far. Basically you are going to have to figure out from what the cars have. Did they both have knock sensors? IRCM? Were the automatic transmissions different? Cooling fans (I rather doubt this one)? The other choice is to open them both up and see what "extras" are in one vs. the other.
steve
'95 GT - T4M0 x2
'93 notch - A9P
'87 TC - 8UA or LB2 or LA3
'84, '85.5 & '86 SVO - PE
'83 & '84 GT turbo - TA x2
86GT
BE/EA Developer
Re: Hardware Specs
Post by 86GT » Tue Nov 22, 2011 6:35 pm
There is a spreadsheet that tells which catch code belong to what hardware and what hardware is an upgrade for others but there is nothing i know of that tells the details of the hardware internals
