vengines
EEC-V Modifing vid block without getting code p0602?
Post by vengines » Sat Feb 11, 2017 11:05 pm
Hello i have a bin file for a 03 for escape and am setup on the bench to read/write but everytime i change the VID block (value i am changing is the VIN) i get a P0602 programming error. is there a checksum? or something else that has to be changed so i no longer get the code, if i disable the VID block i get a VID block failure code.
Also on a side note i would like to disable PATS in the PCM as well, having a hard time finding info on where the SW is in the bin file to disable it.
Any help would be greatly appreciated and included is the original bin i extracted
Re: EEC-V Modifing vid block without getting code p0602?
Post by decipha » Mon Feb 13, 2017 1:14 am
yes the vid block has its own checksum
whatever software your using is not calculating it correctly
Ive done some extensive disassembly of the D0AV7 strategy for the exotics, lmk if u need anything
and why are you disabling pats?
vengines
Post by vengines » Mon Feb 13, 2017 7:23 am
Thanks i used hex workshop once then winols which told me i was changing a protected memory but everytime i change the vin it throws the code i was reading a jaguar writeup that said the last byte of the vid block is the checksum?
Pats off just to learn how and to run it on the bench with a emulator and no tranciever for pats
Do you have a definition xdf for this calibration?
Post by decipha » Mon Feb 13, 2017 4:52 pm
i started one but never finished it
vengines
Post by vengines » Mon Feb 13, 2017 5:43 pm
Do you have any further information on pats disable memory address or VID block checksum i compare the original to the vin changed and only one byte is changed so theres some type of verification on the vid block.
Check this out
http://www.jagrepair.com/images/TSB/TSB ... 0block.pdf
vengines
Post by vengines » Mon Feb 13, 2017 9:18 pm
i might try reflashing with ids and see what it changes first make sure its up to date get a clean bin off the ecu then change one vin digit and then flash it again with the new vin and see what it changes where the checksum is. was hoping some one had run into this before i read about some tuners after a tune leave this code as well but there should be a way to clear it, p0602 is specific to the VID block
rmrmd1956
Post by rmrmd1956 » Sat Jun 03, 2017 4:23 pm
I have disassembled the EEC6 quite a bit. Best way to figure it out really, see
https://www.pcmhacking.net/forums/viewt ... &start=520
