Re: Project on Reverse Engineering binaries, assembly, coding and learning more about the ECU
Post by tvrfan » Fri Dec 18, 2020 8:06 pm
This kind of thing goes on all the time.....We all think some issue/functionality/.../etc has been settled, until a new discovery is made or someone asks a detail question, and then we find out more facts. Despite the docs, there is still quite a lot of little detail unknowns in the software and hardware of the EEC boxes.
Makes things more fun...............
Vehicles - I chose the Toyota 2GR-FE engine. 3.5L V6 DOHC with VVT. Found in V6 Camry, some of the SUVs, small vans etc, and the Lotus Evora. Try engine out if you get the chance - powerful, very smooth, and very good on gas mileage. The 1UZ V8 engine is also very good...it's actually approved for aircraft use !!
(Apologies to die hard Ford fans...)
baba_banana
Post by baba_banana » Sat Dec 26, 2020 4:24 pm
That’s good to know that we’re always learning, gotta chase that satisfaction of completing something first before learning more!
Talking about learning. Made a newbie mistake of not doing some tune ups before heading back on a long trip, engine blew n leaked. Now I’m stuck in a small town in NorCal, probably have to pay someone to replace the engine as I don’t have a garage to tow to.
Happy holidays guys
baba_banana
Post by baba_banana » Fri Jan 01, 2021 7:26 pm
Happy new year guys.
So I didn't know what's gotten into my head: maybe it's being trapped without a car for 6 months or just a crowded living situation. I went on a impulse to get a '95 pathfinder whose engine I blew on my way back at NorCal. I didn't know what I was thinking.. i checked rust, body, interior, engine bay, drove it. Feels smooth at the time but I didn't check oil or coolant or most importantly just use a damn obd scanner or get oil/coolant change before I left. I guess it's amazing that it got me from seattle to oregon (where I made a slight detour to a small town) before breaking down on i5- south.
At this point I'm thinking of just junking it or negotiate with the shop to use its space and tools for engine swap (but I don't think I have the time for that. we'll see..)
Do any of you know what values on a OBD scanner I should be seeing for a Ford Excursion '04 6.0l diesel? By doing some quick read, I can see the pairing of elm327 forscan device + torque pro app make a good combination. The O'reilly closes to me only sells Innova 1000, so i'm not sure if I can get as good of a reading as elm327.
Thought I would post on forum first before I do some googling. . i'm in a tight spot in terms of time so I'm only asking for heuristics right now. (although this surfaced with another question of whether I could RE ELM327 first. but it's just an idea off the top of my head)
Any advice/links appreciated.
cheers to 2021
BB
Post by motorhead1991 » Fri Jan 01, 2021 7:58 pm
Man, if I could bolt across Oregon to help you, I would :grin:
baba_banana
Post by baba_banana » Fri Jan 01, 2021 8:32 pm
motorhead1991 wrote: Fri Jan 01, 2021 7:58 pm Man, if I could bolt across Oregon to help you, I would :grin:
Oh dang you’re in Oregon? I made a detour to a Chiloquin on the way back . The highway views were pretty awesome.
ollopa
Post by ollopa » Fri Jan 01, 2021 9:29 pm
Where in NorCal are you stuck? I'm in Santa Rosa if it's anywhere near where you are. I had one of the very early ELM chips with a UART interface and never got very far with it. The HF scantools, on the other hand, are fairly cheap and I haven't had any complaints with them over the years.
baba_banana
Post by baba_banana » Fri Jan 01, 2021 10:06 pm
I’m in los banos, but I would be driving up anyways.. the dealers are up north.. I’ll be hooking it up to my laptop anyways cuz I have no android (would like to have a cheap used one for work though).
Don’t they all use UART? Well as Long as it works..
Post by motorhead1991 » Fri Jan 01, 2021 10:26 pm
baba_banana wrote: Fri Jan 01, 2021 8:32 pm
Nah, I'm in Idaho and that's a long drive
baba_banana
Post by baba_banana » Fri Jan 01, 2021 10:55 pm
Oh lol.
The diesel’s at Montana. I would prolly stop by.
I read some elm327 adapters might not be compatible w diesel at 24V
Post by jsa » Fri Jan 01, 2021 11:21 pm
ELM327's are a bit of hit and miss affair to get a real one.
Yes a good one works well with Torque. I got a Bluetooth version from the UK some time ago. Company doe snot appear to exist anymore.
12V would be typical of most low cost interfaces.
You may need a module that supports commercial vehicles like buses and trucks to get 24V support.
baba_banana
Post by baba_banana » Fri Jan 01, 2021 11:27 pm
Yea I saw one on amazon that’s a hit w/ diesel owners, titled “OHP ELMconfig” at $31.46.
Hell maybe I’ll just make one myself if ELM electronic (assuming that’s the legit company) sells proper kits..
If that’s the case, Imma stop my relentless vagabonding/car camping and go home n start hacking.
Post by jsa » Fri Jan 01, 2021 11:47 pm
baba_banana
Post by baba_banana » Sat Jan 02, 2021 12:00 am
Cool will check it out later..
I’ve seen a post on ForScan where the person modified the tool to use MS-CAN. I don’t know how it’s related to 24V but I see in another post that 2004 onwards use that as auxiliary protocol to CAN.
So perhaps some modules might be excluded.. as I’ve seen on a post where the OP is trying to DIY for his diesel.
baba_banana
Post by baba_banana » Sat Jan 02, 2021 12:13 am
jsa wrote: Fri Jan 01, 2021 11:21 pm ELM327's are a bit of hit and miss affair to get a real one.
How would one do dat actually? Step down the 24V? Is it a complex task?
Post by jsa » Sat Jan 02, 2021 12:27 am
12V or 24V for power supply, the chips are 5V I believe.
The data streams are a mix of voltages depending on which protocol standard.
Check out the documents on the Elm site.
Post by motorhead1991 » Sat Jan 02, 2021 1:39 am
baba_banana wrote: Fri Jan 01, 2021 10:55 pm Oh lol.
Yeah man, there's some neat stuff here around Boise. Just let me know :grin:
baba_banana
Post by baba_banana » Sat Jan 02, 2021 5:01 pm
jsa wrote: Sat Jan 02, 2021 12:27 am 12V or 24V for power supply, the chips are 5V I believe.
Ok yea. I actually have no clue how Bluetooth adapters get their power from. It probably makes sense that it taps the power from the port and on the modded Chinese adapter there’s a switch to go MS-CAN..
I figure I’ll order the obdlink Mx+ and also the cheap Chinese elm327 to open it up and take a look
baba_banana
Post by baba_banana » Sat Jan 02, 2021 5:07 pm
motorhead1991 wrote: Sat Jan 02, 2021 1:39 am
Thanks. I’ve weighed my options and realized I’m severely lacking in options (both in a scan tool and also knowledge) of the vehicles I should consider. . I Guess imma head back down to San Diego and get everything figured out before I make waves in the market!
Was a great experience riding alone for 19hrs thou! Lots to think about and also shop at truck stops! Didn’t realize how much I miss having a ride!!
Anyways if u know of any deals on those big ass mofos, gimme a shoutout! I might consider a 4Runner for reliability too but I’m sure I’ll be more well prepared when I enter the market again!
teal95
Post by teal95 » Thu May 06, 2021 10:57 am
Going back a few steps M0M2 should have OBD-I which would be an output datastream from the EEC.
steve
'95 GT - T4M0 x3
'93 notch - A9P
'87 TC - 8UA or LB2 or LA3 x2
'85.5 & '86 SVO - PE x2
'83 & '84 GT turbo - TA x2
