So I've narrowed it down to this ECU's structure is about 15C7 off from the GSALI structure.
However, as 99.9% of the same values are within the skeleton of the binary, I'm wondering if this would be an ideal candidate for a speed density to MAF swap. Unfortunately I cannot verify the D9S 60 pin is just that, a swap and repin. I've looked at the GSALI pinout but need to be sure it's wired the same. Meaning the GSALI pins vs the P3M.
Since this is a very late 93 5 liter thunderbird ECU, I'm wondering if anyone has verified this before.
Also, this car will have a slot style blow thru MAF and 42's on about 12psi. 93 E10 pump gas.
Does MAF scaling still apply since SAD is identifying this a a 8065 ECU?
Any help is appreciated.
GSALI vs P3M
CDBA4 - DONE
CDAN4 - DONE
CMBA0/CMAI3/6/7/9 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
CDBA4 - DONE
CDAN4 - DONE
CZAJL - DONE
SFI-SD3 - DONE
GSALI - DONE
CCAQE - DONE
P3M-P3MA - DONE
Re: GSALI vs P3M
P3M is an 8065. Runs at 18MHz IIRC.
So it would be like other 18MHz boxes as far as scaling is concerned.
- Attachments
- ECMComparison1.jpg (198.5 KiB) Viewed 3332 times
Users browsing this forum: No registered users and 37 guests
