Sad for Android!
Sad for Android!
Post by motorhead1991 » Tue Dec 25, 2018 3:44 am
Alright.... I guess now is a good a time as ever to announce the project I've been working on...
Since most of us do things on the go, why not disassemble binaries on the device in your pocket?
S4A Video
Combining my two growing skillsets, I created a simple Java interface for Android devices (currently works on 8.0+), and it's nearly ready for release.
Things left to do:
- fix the "about" button behaviour
- fix the "sad" binary for Android (unexpected behaviour)
- push a toast message when a file doesn't exist
- auto-create a dir file from "msg"
- clean up the UI to make it more appealing (and theme friendly)
Re: Sad for Android!
Post by motorhead1991 » Mon Jan 07, 2019 10:45 am
No real news except that it builds with Android Studio now, and should also build with the AOSP source. It also works on Android P, but I need to work on legacy compatibility.
Post by tvrfan » Tue Jan 08, 2019 1:56 pm
Good stuff !!
Does it still use my 'C' code (compiled) with a Java front end ??
I ask as I'm completely ignorant of Android and 'smart device' type OSes, being one of those ex-tech types that has a phone for actually *talking* to people and nothing else. But I do know Android is based on Linux.
I did wonder about other languages which are more portable for/from desktops, like Python or Java.... or something else?
I know Java is very C++ like. so shouldn't be all that hard for me to change/learn.
Post by motorhead1991 » Tue Jan 08, 2019 4:39 pm
Good stuff !!
It does, actually. If you look at the open "Pull request" you'll see all the modifications I made to the code (It wasn't much). It actually cross compiled pretty cleanly, I just need to figure out why it doesn't accept a direct command (vs doing it in two steps).
caish
Post by caish » Fri Mar 08, 2019 10:17 pm
THis is the sort of thing I joined the forum for.
I don't use Windows. (Linux) but was thinking of putting an android based stereo in my Focus,
would be great to have a complete tuning suite, I know this is not that but shows basis it could be done/ built...
Post by motorhead1991 » Tue Mar 12, 2019 12:20 pm
I'm working on communicating with tuning hardware currently. Most apps that can cost money currently.
caish
Post by caish » Thu Mar 14, 2019 7:07 pm
I wouldn't grip paying $20 for an actual working app, not one that is basically an alpha stage of development, a stable beta with upgrade to version 1.0 when finished, sure...
Post by motorhead1991 » Sun Jun 16, 2019 2:25 am
TVRfan's code compiles perfectly fine as a library, meaning I should be able to merge it into the Android system easily, as soon as I figure out how :grin:
I would make more progress on this, but my server puts out a ton of heat, so I'm restricted to wintertime and nighttime use.
