X3Z Pinout Diagram
k19driver
X3Z Pinout Diagram
Post by k19driver » Mon Jun 10, 2019 11:03 pm
Hello all,
If anyone has a pinout of the X3Z EEC-IV Module 5.0L MAF (manual trans) If it is possible to get a copy I'd really appreciate it.
Thanks.
1993 Volvo 940 wagon w/347ci stroked Ford, ported GT-40 aluminum heads, 10.2 to 1 CR, Track Heat manifold, JBA shorty headers into a single 3' exhaust, Dodge Reidy custom cam w/ 1.6 to 1 roller rockers, FMS Cobra X3Z computer w/TwEECer RT, 30 lb injectors, 75mm Pro-M MAF, BBK 73 throttle body, BBK fuel press regulator and rails, K&N filter, cold air box, FMS underdrive pulleys, modified Canton oil pan, 155lph Volvo fuel pump, Tremec 3550II gearbox, SPEC clutch, 3.54 gears, PowrLok LS diff, ipd bars and springs, Koni dampers, 13' Wilwood front rotors/calipers, 245x45 on 17x9 and 225x50 on 17x7.5, 3375 lbs dry.
Re: X3Z Pinout Diagram
Post by cgrey8 » Tue Jun 11, 2019 5:11 am
It's the same as an A9L. Plenty of info on it. Just google A9L pinout. That should get you what you want.
Post by EDS50 » Thu Jun 13, 2019 9:42 am
Hello all,
Thanks.
http://www.veryuseful.com/mustang/tech/engine/#Diagrams
k19driver
Post by k19driver » Fri Nov 29, 2019 2:23 pm
Thanks gentlemen.
