RobFoxDog
02sensor delete in a drag only car
Post by RobFoxDog » Mon Jun 01, 2020 12:51 pm
New to tuning ,my first efi drag car, 302, 5 speed, RPM heads and intake , xe274hr cam , l.tube headers, can I deleate the 02s? i have a Holly wideband to monitior afr, thoughts?
Re: 02sensor delete in a drag only car
Post by motorhead1991 » Tue Jun 02, 2020 12:36 am
RobFoxDog wrote: ↑Mon Jun 01, 2020 12:51 pm New to tuning ,my first efi drag car, 302, 5 speed, RPM heads and intake , xe274hr cam , l.tube headers, can I deleate the 02s? i have a Holly wideband to monitior afr, thoughts?
That should be fine, if you disable them in the tune and force open loop to be safe.
Post by cgrey8 » Tue Jun 02, 2020 6:47 am
It doesn't really matter whether you disable them or not if you force Open Loop. Only Closed Loop fueling is going to "look" at them during normal runtime.
KOER tests might would still care, but my guess is a dedicated drag car isn't going to be doing a lot of KOER tests.
