Post
by xr4x4ti » Sat Jul 07, 2007 10:02 am
Wow, my thread has exploided:)
Well, I did find one problem with my AEM setup yesterday that could explain my lack of repeatability. The stock ACT in the intake seems to instantly heat soke and is useless. Basically after the car warms up it reads a constant 176ºF (I am running a 180ºF stat). That is not acceptable in a speed density system. First I will try putting a brand new plastic bodied sensor in the intake manifold. If that doesn’t work I will put a GM sensor in the tube between the turbo and TB.
I actually have been researching this in some detail and I agree the EEC-V is probably better. I just was concerned that it would be another case where I was making it more complicated then it had to be. I have actually talked to SCT a few times and they have been very helpful. If I go EEC-V, that is the software I would use. My local tuner shop that is AEM certified and has the SCT software also agrees, that if I go Ford, I should use an EEC-V.
SCT explained to me how it was quite easy to set the max load to 200% in the EEC-V's and a few other good things. They also mentioned that I could even get an EEC-V from a '96 F150 or Bronco with a 302 or 351 and I could use a TFI distributor! That is what Saleen did to make the S351 in the late 90's after Ford quit putting the small block in the mustangs. They did warn me that the older computers are not quite as powerful as the newer ones. I am not sure what that means. The newer computers require DIS and I am not sure if I can use a computer that came factory with a returnless fuel system. I actually picked up a computer from a '99 explorer 5.0 the other day, but when I found the wiring diagram I realized that it had the returnless fuel system. The wiring diagram for the '96 F-150 looks pretty simple and I have already found some cars in the local U-Pull-it with EEC-V connectors.
If I stay EEC-IV, what is better then an A9L? I don’t know all of the different codes, but would I be better off with a 94-95 Mustang, 93-95 Cobra? Are they more load based? Does the Tweecer fully support them?
Thanks in advance,
Tim
XR4X4Ti
