cgrey8 wrote:Nobody's bashing you personally, at least I don't think they are. But they are bashing your method. The method you are describing is an outdated method of tuning and hinges off the same methods used to get an engine running without a tune...which truly is lying to the EEC about what the actual running conditions of the engine are in an effort to coerce it to do something desirable. I will admit it may be a faster method of tuning to start with because things are likely to run better right off the bat. Ultimately as long as the right amount of fuel and spark advance is applied at the right RPM/Loads, it doesn't really matter how you tune the computer. But it makes things terribly more confusing when others review the tune and datalogs later and find a datalogged Load of 75% is actually 10PSI of boost or some such. Thus why keeping the stock settings for MAF and Injector Slope/BP/Offset is still lying to the EEC about what the actual conditions of the engine.dsblk93gt wrote:I was just trying to help him out with what I've seen works, again, I never claimed to know it all. If there is a better way by all means try that, but I kinda feel like I'm getting bashed slightly for trying to help a guy get his car at least running.
The other guys here are just trying to show that if you want the EEC to be more informed of the true condition of the engine, then you need the EEC to be aware of actual MAF, Injector characteristics so that when you datalog, you datalog boosted conditions as loads above 100% and thus you can adjust spark accordingly. As well, having the datalog filled with actual running conditions makes it easier to diagnose problems as well as makes it easier for others to review the logs and tune to help.
But it's up to the tuner how he/she wants to tune their engine. The only wrong ways to tune are the ways that don't work and blow the engine up! But of the ways that get the engine running right, there are some methods that are more correct than others to make the datalogs come out with lucid info that describes the true running conditions of the engine. If you ONLY care about the engine, then whatever works, works and nobody will know the difference. But if you want to share your logs with others so others can help you with problems, the datalog needs to make sense and 75% Load for a 10PSI condition is not lucid info and will cause as much confusion as it gives insight.
For your enthusiasm to help though is admirable and one I hope isn't stifled by the differences of opinion in this matter. Stick around. We hope to learn from others just as much as others learn from us...or at least I do.
I agree that is is backwards and thats why I don't ever use an aftermarket meter calibrated for an injector size. I always use a OEM Ford meter. The loadds are always all screwed up, I had tons of issues with my 93 LX when my friend owned it still. I tuned it with the PMS vs 4 and he has a Pro M 75mm MAF and 42lbers. It ran awesome at WOT and idled great but at part throttle the car was a nightmare to get to run correct. Then of course since any changes to part throttle you make with the PMS just get learned by the stock ECU it was pointless.
I was trying to help him get it running correct with what he had to work with and totally understand it is hard to tune a car with a meter like that.
If he had a 90mm LMAF for example he would have been fine doing it the way he was in the 1st place. But with a aftermarket meter that is made to fool the stock ecu into there is no way it will run right since the voltage output has been scaled down so much.
I appreciate the response and I'm always up for learning more, I'm not trying to steer anyone in the wrong direction at all.
