Re: Help, EEC will not log any data above 5400 RPM
THANK YOU, JOHN (SKUNK). That was it, the checksum base. I set it to 8192 and bingo! There POWER IS BACK.
306 w/9.25 to 1 comp w/ A4 block, TFS heads, 93 Cobra Crane cam for 1.7 rockers but using 1.6's, 60lbs injectors, Pro-m 75mm blowthru MAF, twin turbo's t61's @ 16psi, Victor 5.0 intake, 75mm tb, T56 Magnum 6 speed, 3.55 gears,A9L EEC, TwEECer RT, Inovative LM-1
Your welcome......thanks for posting the results! Always great to see problem threads with closure.
1987 Turbocoupe.
A3M1/A9L, BE/EA, Tweecer RT.
Users browsing this forum: No registered users and 89 guests
