Thanks John,
Not sure if I know how to sort that, as it's a Win32 call to do the dialogs.....
But I'll have a web look and see if there's any info.
It's an XP dialog originally so may be because it's very old by now...(I built SADWIN on an XP virtual machine)
I've got a Win 8 VM somewhere..... I'll try it on that.
A further thought, are you intending to call the folder selection window when the path to sad.exe is broken, in the ini?
If so, could be the call is incorrect or has the wrong arguments.
I have an XP VM on my laptop. I shall fire it up later and see what happens....
No - designed the last one as an 'OpenFile dialog' so that you can change the name of SAD.exe you wish (like for example have more than one version at the same time) and OpenFile gets the whole path, so went that way.
The official m$ docs actually say if you're using Vista or later to use an alternate dialog call, but of course the calls ain't there on an XP VM !
I was going to try out WxWidgets, which is supposed to be platform independent also, as far as Win and Linux go, but couldn't get compile to work
with Codeblocks. Very frustrating. Managed to sort that just this morning, solution was not very obvious, hidden away in Install docs.
One of those "in some cases......." gotcha statements near the end.
It's sometimes a real PITA, but good to learn the different techniques. Most of my background was in the server end with databases and custom written services, so did a lot of 'C', perl and various scripting, but no GUI stuff....
Ok makes sense.
John,
Tried out that setup on a Win 8.1 64 VM, and it doesn't seem to produce duplicates as your example (but the colours are truly awful !!).
Used the XP 32 bit builds. I see win 8.1 automatically shows the later style directory dialog picker (as I understand it).
Everything runs OK and it disassembles fine.
Did you say you were on Win 7 ? Hmm... haven't got one at the moment, I'll see if I can get one from the "Buccaneer Inlet"
if you know what I mean.......
Re: 3.03 posted, Windows EXE posted
Hey, I like a GUI sometimes... Taking a small break from this to run off a couple Android builds though
I look upon Win 8 as Vista 2tvrfan wrote: ↑Thu Feb 15, 2018 11:54 pm John,
Yes, Win 7 x64 Ultimate SP1. I'll have a go with my laptop which is same OS plus VM XP.
Ay cap'n
The casts are muck'n up a bit. I ran your a9l cmt and dir through V3.03 and compared to your lst.
JC and JNC are getting pairs of (uns)
2046: d3,f5 jnc 203d if ((uns) (uns) R14 < 48a) goto 203d;
2077: db,0e jc 2087 if ((uns) (uns) R14 < R16) {
206c: df,20 je 208e if (R14 = ffff) goto 208e; # -1 = list processing done
2108: d7,03 jne 210d if (0 = Kihp) {
2237: de,22 jlt 225b if (AD_Cmd < 0) goto 225b;
24ad: d2,12 jgt 24c1 if (R8a <= 0) {
270b: e0,50,05 djnz R50,2713 R50--;
if (R50 != 0) goto 2713;
Now I've got the minimal WxWidgets example to compile and run, I'll learn this way instead and then there will be a GUI for both platforms.motorhead1991 wrote: ↑Fri Feb 16, 2018 2:13 am Hey, I like a GUI sometimes... Taking a small break from this to run off a couple Android builds though![]()
I also finally managed to get git to talk to my remote repository on GitHub, so will try a push/pull/commit etc to testing branch to learn that too.
All good - keeps the brain working !
Bugger - I left an extra (uns) in the code !! I have cheated and fixed that in 3.03 (src and bin) as it's only an extra print statement I should have commented out....jsa wrote: ↑Fri Feb 16, 2018 4:22 am
.. The casts are muck'n up a bit. I ran your a9l cmt and dir through V3.03 and compared to your lst.
JC and JNC are getting pairs of (uns)Code: Select all
2046: d3,f5 jnc 203d if ((uns) (uns) R14 < 48a) goto 203d; 2077: db,0e jc 2087 if ((uns) (uns) R14 < R16) {
JE, JNE, JLT, JGT, DJNZ get nothing ?
These are all SIGNED operations, so didn't add anything. (hmm, must check DJNZ though )
I agree with adding long and uns, on the basis that a signed int (16 bit word) or signed byte is the default.
I'm open to suggestions as to how this might be improved without being too fussy.
I don't really want to make every comparison have (signed)(int) all over the place.
Idea - I did originally print every register as R14B, R14W, R14L but it looked messy/weird with absolute addresses and numbers.
Weird to me that is, but I'm embedded in this stuff.
If you guys reckon it's clearer I can put that format back in, or something like it.
Or could perhaps state in Doc that signed word/int is default ??
Haha I see the git source has been updated.
Would you like to cheat a little more...
Edit: I had already appended .1 for my build with version out to lst and msg
shared.h
#define SADVERSION "3.03.2"
Core.cpp
newl(1);
pstr("#\n# Disassembled by SAD V%s\n",SADVERSION); //Add this to print SAD Version in *lst.txt
pstr("#\n# Disassembly listing of binary '%s' ",fldata.bare);
wnprtn("\n\n --- Disassembled by SAD V%s",SADVERSION); //Add this to print SAD Version in *msg.txt
wnprtn("\n ------------- START Disassembly");
Having to check stuff in the reference material is a large part of my reasoning for having the casts explicit. Working on the disassembly's sporadically as time permits means that not all the finer points are ingrained in memory. After a break from disassembly, I find I spend a fair amount of unproductive time reviewing reference material to double check what I think I remember.JE, JNE, JLT, JGT, DJNZ get nothing ?
I had to go look up the ford reference before making a ? as to why you might leave them out.
Now I see in the ford reference, DJNZ notes, that there are differences for 8061 & 8065.....
I agree with keeping a balance between explicit information and untidy information making output difficult to read.I'm open to suggestions as to how this might be improved without being too fussy.
I really like the explicit hint for lookups. I think keep it down to just a single letter.
U Unsigned
S Signed
2077: db,0e jc 2087 if ((U) R14 < R16) {
or
2077: db,0e jc 2087 if (U R14 < R16) {
206c: df,20 je 208e if ((S) R14 = ffff) goto 208e;
or
206c: df,20 je 208e if (S R14 = ffff) goto 208e;
In your experience, what value is there in the ()?
Was there a R14H as well at some point?Idea - I did originally print every register as R14B, R14W, R14L but it looked messy/weird with absolute addresses and numbers.
The B & W seem to be well covered by the opcode names which typically have a b or w suffix. So I don't think blanket B&W are going to add anything. Have you a listing you could share with blanket B,W & L?
If the B, W and L are tied to the Rxx, then B, W & L could be lost after Rxx is replaced by SYM with SomeName.
I agree some combinations of SomeNameL would just add confusion.
The detail that can be easily missed, is the change from B to W or W to L. I find it is the implicit changes that I want to be reminded of.
I say make it consistent so that they are shown as prefixes, but not directly appended to the Rxx.
change
2971: 6c,be,50 ml2w R50,Rbe (long) R50 *= PIPH_PW;
to
2971: 6c,be,50 ml2w R50,Rbe L R50 *= PIPH_PW;
or (L) R50
My gut feel is that, by quantity most of the code is working on unsigned values. So signed by default seems counterintuitive to me.Or could perhaps state in Doc that signed word/int is default ??
Having to reference external material while following through code is a real train of thought breaker. Minimising that helps productivity, so I'm all for explicit hints.
How many of us are formally trained and know the implicit details straight up each time we return to disassembly?
John,
some good points there....
Yes for version number, should add that to list and warn files. Good idea.
the (long) with brackets comes straight from 'C' code, where you can recast a value as something else...
If we go for a shorthand like (U) then perhaps I should print a key at the top ?
R14H meaning high ?, unfortunately it's R15. if it's a long, then it's R17 ...
Abandoned the R14B etc a long time ago, I decided (like you) the opcode was good enough most of the time, and so just the implicit/specific changes
to highlight.
Signed/unsigned - tricky territory (believe it or not).
Many Arithmetic ops are totally blind to sign because of a very clever trick - have you ever wondered why (16 bit) -1 is 0xffff and -32768 is 0x8000?
so that add is quite literally a+b in all 16 bits, in all cases. Neat. So really signed is only for compares and jumps (and a few odd opcodes where sign bit
screws stuff up, like shifts, mults). Yeah, OK, not quite always, but holding this idea in your head helps.
In C code for example you quite often have a mixed of signed and unsigned ints...
Also non-programmers will possibly miss tricks like this, which us IT geeks see straight away...
But I don't know how to show this reliably in SAD !!
Anyway, I'll think seriously about your suggestions....
to highlight.
LDW, R14, R26; R14 = R26;
LDW R30, R15; R30 = R26/256;
MULT R34, R32 (L) R34 = R34 * R32;
LDX R30, R36 R30 = (R34 * R32) / 65536
That UI I showed you in PM is written with QT, which is cross-platform compatible. That means, if we can figure out how to integrate it, everyone's UI will look the same. I don't know enough C to do it just yet though.tvrfan wrote: ↑Fri Feb 16, 2018 2:14 pmNow I've got the minimal WxWidgets example to compile and run, I'll learn this way instead and then there will be a GUI for both platforms.motorhead1991 wrote: ↑Fri Feb 16, 2018 2:13 am Hey, I like a GUI sometimes... Taking a small break from this to run off a couple Android builds though![]()
For everyone else, who hasn't seen it, here;
https://youtu.be/OH_S6pRbX64
I just want to insert my 7 cents. last year I disassembled GM binary fom gm C3 ecu. It was as usual - see, what parts of code are the same with known parts in already disassembled binary, and write what it is. I used ida pro, since gm used supported motorola mcu (and much less tricks).
what can I say? I had nearly the same progress in 1 month with gm binary, as in 1 year with eec-iv binary.
apart from ida pro, there are opensource and free disassemblers, say 'radare2' (currently not supporting i8061). it's much better to use existing debugging interface than commandline tool, windows gui wrapper or anything else.
Well, I tried it on my Win7 x64 Ult laptop now, and what do you know, no additional instance of windows explorer.
Both machines have the same Windows updates and the settings are cloned with migration wizard. Workstation is a Gen 1 i7 and the laptop Gen 6 i7. Workstation has a lot more applications installed.
In summary something specific to my workstation, that is not worth chasing.
At a wild guess, maybe a runtime dll brought in by another application.
So, no point spending more of your time on it unless more have the same experience.
I had added a glossary of sorts to my cmt file.
It contains a couple notes about PSW flags and detail for name abbreviations used in my Sym names.
How about, in the absence of a user cmt file, generate a default cmt with default glossary, and run the lst file generation after that?
Yes, high was the context, but I don't recall where I saw it in use. May have been something on Decipha's site. May be as a result of a SYM name.R14H meaning high ?, unfortunately it's R15. if it's a long, then it's R17 ...
Yes, R15 and R17.
oh yeah, have googled it more than once. The seemingly chaotic concepts that work for binary machines.Signed/unsigned - tricky territory (believe it or not).
Hmmmm, a perfect example of an implicit meaning a non-programmer overlooks!!!
LOL, now that's just taking the mickey.Code: Select all
MULT R34, R32 (L) R34 = R34 * R32; LDX R30, R36 R30 = (R34 * R32) / 32768
Indeed, I have nothing right now.But I don't know how to show this reliably in SAD !!
Good stuff, looks alright.
I did have a look at IDA, because you can (apparently) write plugins for any CPU. However I couldn't find decent docs on how to write one, and (in my head) what I could see got very complicated. I know it's very highly rated for x86 stuff though. Any links you might have are welcome, I'll have a read.ender11 wrote: ↑Sat Feb 17, 2018 5:30 am I just want to insert my 7 cents. last year I disassembled GM binary fom gm C3 ecu. It was as usual - see, what parts of code are the same with known parts in already disassembled binary, and write what it is. I used ida pro, since gm used supported motorola mcu (and much less tricks).
what can I say? I had nearly the same progress in 1 month with gm binary, as in 1 year with eec-iv binary. apart from ida pro, there are opensource and free disassemblers, say 'radare2' (currently not supporting i8061). it's much better to use existing debugging interface than commandline tool, windows gui wrapper or anything else.
Funny that - I installed radare2 on my workstation to have a play with it....
GM Ecu - if it's the 68HC11 (definitely is on early 90's GMs) then that CPU has a much simpler opcode set. I did actually write a mini SAD for that for 'fun' (and to help a bit with understanding). But then GM released a whole load of good info, and it's a standard industry CPU chip.
But Ford didn't go that way.
Great Idea - My answer - I'll have a 'default comment' file, with a glossary (etc) in it, and then have a command option whether to print it or not.jsa wrote: ↑Sat Feb 17, 2018 7:19 am
Then it fits in neatly with existing structure, and can be switched off.
A little lecture in case it helps...
The A9L listings have quite a lot of symxxL and symxxH which are for 32 (or 24) bit values. On later bins which have faster clock speeds A lot (all?) of them tend to have a 24 bit clock. When long adds appear you will see an ADDC (add with Carry) for the top (H) value after the lower (L) add. 32 bit adds (etc) have an ADCW (add word + carry) and 24 bit have ADCB (byte). This is the way to spot them.
I did consider doing this in SAD, but there are places where logic tricks mess this up....(they are all over the place !)
Arithmetics and sign. It makes sense once you get your head around it. Does it help if I say that ->
0x8000 -> 0xffff (= 0x0 -> 0x7ffff with sign bit set) is -32768 -> -1. Think of it as (0 -> 32767) minus 32768
0 -> 0x7fff (no sign bit) is 0 -> 32767
So there are two identical 'ranges' of 32768 values, which work in the same direction and are contiguous, so therefore plus and minus works seamlessly across those ranges with no extra work. By conventional maths, I guess it's true to say the sign bit is actually backwards (i.e. it should not be set for minus), but it gives a 'free' NEG flag for the PSW, and overflow from negative through to positive works correctly as it's only a binary bit.
If you go unsigned (no signed flag) 0 - 65536 works too. You can say that signed arithmetic simply shifts all values downwards by 32768.
As well as those implicit divides in my last post, quite a bit of the Ford code has shifts for divide and multiply.
I have replaced these in SAD where I think it makes sense.
so SHR 4 (shift right 4) = Value/16 and SHL 4 = Value *16;
As a lot of stuff is binary scaled (like for example say, stoich mixture is 0x4000) it then becomes simpler (and faster) to mess with.
Fount THIS in A9L for example...
2b22: c3,74,1e,54 stw R54,[R74+1e] Sapw = R54; # Spark Angle Pulse Width, msec.
2b26: 6d,ab,6a,54 ml2w R54,6aab (long) R54 *= 6aab;
2b2a: 75,80,55 ad2b R55,80 R55 += 80;
2b2d: a4,00,56 adcw R56,R0 R56 += CY;
2b30: c3,74,ca,56 stw R56,[R74+ca] Spout_low_time = R56;
And from memory that 0.416 appears quite a bit in A9L timed stuff, so will equate somewhere to (a scaled) ticks per millisec or millisecs per tick
Very good, I reckon run with that.
Thanks, good hint to be mindful of.A little lecture in case it helps...
I just keep in mind, that the absolute value increases from B0 to B6.
Yes, the decimal equivalent equation is very helpful in the output list.I have replaced these in SAD where I think it makes sense.
Long may it live....
not much stuff - https://blog.quarkslab.com/ida-processor-module.htmltvrfan wrote: ↑Sat Feb 17, 2018 1:47 pm I did have a look at IDA, because you can (apparently) write plugins for any CPU. However I couldn't find decent docs on how to write one, and (in my head) what I could see got very complicated. I know it's very highly rated for x86 stuff though. Any links you might have are welcome, I'll have a read.
also, you should have ida pro sdk unpacked. it contains intel 80196 processor module sources, which may be a start point. but, as I can see, that operations - redefining operands, code chunks etc are usually perfomed with python scripts in ida.
never heared about it, how can I take a look at that? cpu is ok in gm ecu, but there are other strange chips there.
Thanks for the link. I will have a read. I've not used Python before, so some learning there.ender11 wrote: ↑Sun Feb 18, 2018 5:18 am not much stuff - https://blog.quarkslab.com/ida-processor-module.html
I admit I haven't personally seen any specific stuff for GM ECU, apart from how to read the codes, but several blogs I read said the info is freely available, but I didn't look. Could be confusion over use of a standard CPU, and the HC11 stuff WAS freely available. I thought the supporting chips were standard too ?
You can always try the chip numbers in google - it's pretty good at finding them.
OK, sorry about that. My error. So it's just as custom as the Ford ECU, except for the CPU.....
Re: dir & cmt changes
tvrfan,
Between V0.5 and V3.03 I see some differences in the cmt output for the table and function lookups.
The old command option, : F 2 38 34, gives odd results if added to the option string in the V3.03 dir.
Could you give an overview of the new lookup option strings output to the cmt?
Table Look Up seems to work for this code segment using the default from V3.03 cmt
Function Look Up seems to need the old option strings without the :
I saw the : mentioned in an earlier post by ender11.
https://eectuning.org/forums/viewtopic. ... 20#p130001
Edit1: Word LU's are giving unexpected results as well. Looks like something's up with LU's that take two word size arguments.
Edit2:
Symbol defined in dir
CARD Code, output to lst on L264A & L2660 looks to be incorrect
Edit3
Some more CARD with V3.03
I have unsuccessfully tried a few ways to define 2 words and a byte as the arguments to Sub459F.
This is how it looks with 5 bytes, thoughts on getting 2W and 1B?
V0.5 cmt output
sub 263c "UTabLU" : F 2 38 34
V3.03 cmt output
sub 263c "Sub263C_TabLu1" #S #spf :TBLU L1=0* L2=0 P=0 D=0 A=878b0
V0.5 cmt output
sub 7773 "UUByteLU" :E 2 f0 N :W N : F 1 1 1
V3.03 cmt output misses the arguments if pasted to dir
sub 7773 "Sub7773_BFuncLu4" #sz1 4 #S: E 4 f0 N [Af0 D32] : Y O 2 [A0 D34] #spf :testx L1=1* L2=0 P=4 D=32 A=87773 :FnLU L1=0* L2=0 P=0 D=0 A=87794
V3.03 this dir string without : captures the first word argument but the second is shown as 2bytes, not a word.
sub 7773 "Sub7773_BFuncLu4" E 2 f0 N W N F 1 1 1
Edit2:
SYM DCEF "Address_DCEF"
Sub263C_TabLu1:
263c: f9 stc CY = 1
263d: 00 skip goto 263f;
263e: f8
263f: a3,72,b0,30 ldw R30,[R72+b0] R30 = [530];
2643: a3,72,b2,32 ldw R32,[R72+b2] R32 = [532];
2647: ad,0b,34 ldzbw R34,b R34 = (uns)b;
264a: db,03 jc 264f if ((uns) 0 >= Address_DCEF) goto 264f;
264c: e7,61,52 jump 78b0 goto Sub78b0_TabLu8;
264f: e7,5b,52 jump 78ad goto Sub78ad_TabLu7;
Sub2652_TabLu2:
2652: f9 stc CY = 1
2653: 00 skip goto 2655;
Sub2654_TabLu3:
2654: f8 clc CY = 0
2655: af,72,b4,30 ldzbw R30,[R72+b4] R30 = (uns)[534];
2659: af,72,b5,32 ldzbw R32,[R72+b5] R32 = (uns)[535];
265d: ad,06,34 ldzbw R34,6 R34 = (uns)6;
2660: db,03 jc 2665 if ((uns) 0 >= Address_DCEF) goto 2665;
2e99: ef,03,17 call 459f Sub459F(2,0,80,46,0);
2e9c: 02,00,80,46,00 #args
Those extra comments are again for my debug (L1 = level1, L2 = level2 (how many subroutines back via POP) d = data register a = address and P = num args) SZ1 (and SZ2) are end result of num arguments. S means subr has signatures detected inside it (because a subr can call other subrs to do their argument work...).
:F It doesn't do anything anymore , so not surprised is prints wrong values - I should have dropped it from options allowed.
BUT now I see this means a manual command has no way of defining a function lookup subroutine.... Damn! I made a hole there....
And -
That code example is EXCELLENT !! AND INCREDIBLY ANNOYING !!!!!
Seriously - extra thanks and kudos to you for finding this.
- what's going wrong - LDW and LDZBW don't change PSW, so the JC is looking back to find the last opcode which changed the PSW. Complicated by the SKIP, which is treated as a GOTO, so it is marked as end of scan block and 263f starts a NEW block scan. This explains why 263e is skipped over, because it's a Clear Carry (CLC) which would be CALLed by someone - (signed/unsigned) but may not be used. So JC is finding something it should not for its compare..... what it should do is print a simple " If (Carry == 1) " as it should not find a PSW changer.... Um......
I'll have to study this one !! There's probably more occurrences then....
For a subroutine with different data types do them in order, you should be able to do a command -
sub 12345 "somesub" : W O 2 : Y
or
sub 12345 : W : W : Y
which is 2 words followed by 1 byte (and name is optional)
And -
or
To explain a bit more, I should probably add that when code scan blocks are closed and new ones added, they aren't necessarily done in order, as they go in an ordered queue, so what that JC picked up could possibly be a long way away....
Yeah, just not working in V3.03 in general, for many different subr's.
I might want
Sub "2345_My_Sub" : W N : Y N : W N
At the moment function LU sub's are splitting the last word in to bytes unless I do this;
sub 7770 "Sub7770_BFuncLu3" : W N O 2
But then the Sym defined name for the first word is not used.
The old style options allow the name to show for the first word, but not the second, particularly with it being split into 2 bytes.
Thanks for the explanations on other queries.
Looking forward to V3.04.
Edit 1
This
sub 7770 "Sub7770_BFuncLu3" : W N : W N
Gives
2457: ef,16,53 call 7770 Sub7770_BFuncLu3(8268,);
245a: 68,82 #args
Ignoring the name and second word argument.
John - that trailing comma in args gives me a clue ",)" at the end - The code adds a comma if there's more data to go, but then doesn't get printed - probably the size calc (which is master check) is screwed up (i.e. set to 2 instead of 4) ... Hmmm.
in xx_msg.txt do you see something like
sub 1234 "somesub" #sz1 2 #S: W N : W N ? that would confirm my suspicion.... (sz1 should be 4)
OOps, must fix comments to come AFTER the data definition so it can be reused in dir file....
Note the args on the next line. The second word is not on the args line.
Another example
sub 41fe "Sub41fe" : W : Y : Y
or
sub 41fe "Sub41fe" : W : Y O 2
or
sub 41fe "Sub41fe" : W : WCode: Select all
3f66: 2a,96 scall 41fe Sub41fe(3,);
3f68: 03,00 #args
3f6a: 20,dc sjmp 4048 goto 4048;msg out
sub 41fe "Sub41fe" #sz1 2 #cmd #S: W [A0 D0] : Y [A0 D0] : Y [A0 D0]
or
sub 41fe "Sub41fe" #sz1 2 #cmd #S: W [A0 D0] : W [A0 D0] Code: Select all
sub 41fe "Sub41fe" : W N O 2Code: Select all
3f66: 2a,96 scall 41fe Sub41fe(LIO_Port,dc20);
3f68: 03,00,20,dc #args
sub 41fe "Sub41fe" #sz1 4 #cmd #S: W O 2 N [A0 D0] Cheers
JSA - Thanks for that.
Found - problem on subroutine args size is only from a directive command, not from an auto added one.
But the Carry one goes deeper, and in fact I'm still not happy that it reports correctly.
Carry may mean different limits (e.g for subtract it's a borrow, add it's an overflow, shift ....) so I'm not convinced that my
(uns) xxx > 0 style is correct, I may have to add code which looks at what the previous opcode actually is....
So, I want to fix it properly. May be a few days....
Ok, thanks.
