Re: Project on Reverse Engineering binaries, assembly, coding and learning more about the ECU
Post by tvrfan » Fri Dec 18, 2020 8:06 pm
This kind of thing goes on all the time.....We all think some issue/functionality/.../etc has been settled, until a new discovery is made or someone asks a detail question, and then we find out more facts. Despite the docs, there is still quite a lot of little detail unknowns in the software and hardware of the EEC boxes.
Makes things more fun...............
Vehicles - I chose the Toyota 2GR-FE engine. 3.5L V6 DOHC with VVT. Found in V6 Camry, some of the SUVs, small vans etc, and the Lotus Evora. Try engine out if you get the chance - powerful, very smooth, and very good on gas mileage. The 1UZ V8 engine is also very good...it's actually approved for aircraft use !!
(Apologies to die hard Ford fans...)
baba_banana
Post by baba_banana » Sat Dec 26, 2020 4:24 pm
That’s good to know that we’re always learning, gotta chase that satisfaction of completing something first before learning more!
Talking about learning. Made a newbie mistake of not doing some tune ups before heading back on a long trip, engine blew n leaked. Now I’m stuck in a small town in NorCal, probably have to pay someone to replace the engine as I don’t have a garage to tow to.
Happy holidays guys
baba_banana
Post by baba_banana » Fri Jan 01, 2021 7:26 pm
Happy new year guys.
So I didn't know what's gotten into my head: maybe it's being trapped without a car for 6 months or just a crowded living situation. I went on a impulse to get a '95 pathfinder whose engine I blew on my way back at NorCal. I didn't know what I was thinking.. i checked rust, body, interior, engine bay, drove it. Feels smooth at the time but I didn't check oil or coolant or most importantly just use a damn obd scanner or get oil/coolant change before I left. I guess it's amazing that it got me from seattle to oregon (where I made a slight detour to a small town) before breaking down on i5- south.
At this point I'm thinking of just junking it or negotiate with the shop to use its space and tools for engine swap (but I don't think I have the time for that. we'll see..)
Do any of you know what values on a OBD scanner I should be seeing for a Ford Excursion '04 6.0l diesel? By doing some quick read, I can see the pairing of elm327 forscan device + torque pro app make a good combination. The O'reilly closes to me only sells Innova 1000, so i'm not sure if I can get as good of a reading as elm327.
Thought I would post on forum first before I do some googling. . i'm in a tight spot in terms of time so I'm only asking for heuristics right now. (although this surfaced with another question of whether I could RE ELM327 first. but it's just an idea off the top of my head)
Any advice/links appreciated.
cheers to 2021
BB
Post by motorhead1991 » Fri Jan 01, 2021 7:58 pm
Man, if I could bolt across Oregon to help you, I would :grin:
baba_banana
Post by baba_banana » Fri Jan 01, 2021 8:32 pm
motorhead1991 wrote: ↑Fri Jan 01, 2021 7:58 pm Man, if I could bolt across Oregon to help you, I would :grin:
Oh dang you’re in Oregon? I made a detour to a Chiloquin on the way back . The highway views were pretty awesome.
ollopa
Post by ollopa » Fri Jan 01, 2021 9:29 pm
Where in NorCal are you stuck? I'm in Santa Rosa if it's anywhere near where you are. I had one of the very early ELM chips with a UART interface and never got very far with it. The HF scantools, on the other hand, are fairly cheap and I haven't had any complaints with them over the years.
baba_banana
Post by baba_banana » Fri Jan 01, 2021 10:06 pm
I’m in los banos, but I would be driving up anyways.. the dealers are up north.. I’ll be hooking it up to my laptop anyways cuz I have no android (would like to have a cheap used one for work though).
Don’t they all use UART? Well as Long as it works..
Post by motorhead1991 » Fri Jan 01, 2021 10:26 pm
baba_banana wrote: ↑Fri Jan 01, 2021 8:32 pm
Nah, I'm in Idaho and that's a long drive
baba_banana
Post by baba_banana » Fri Jan 01, 2021 10:55 pm
Oh lol.
The diesel’s at Montana. I would prolly stop by.
I read some elm327 adapters might not be compatible w diesel at 24V
Post by jsa » Fri Jan 01, 2021 11:21 pm
ELM327's are a bit of hit and miss affair to get a real one.
Yes a good one works well with Torque. I got a Bluetooth version from the UK some time ago. Company doe snot appear to exist anymore.
12V would be typical of most low cost interfaces.
You may need a module that supports commercial vehicles like buses and trucks to get 24V support.
baba_banana
Post by baba_banana » Fri Jan 01, 2021 11:27 pm
Yea I saw one on amazon that’s a hit w/ diesel owners, titled “OHP ELMconfig” at $31.46.
Hell maybe I’ll just make one myself if ELM electronic (assuming that’s the legit company) sells proper kits..
If that’s the case, Imma stop my relentless vagabonding/car camping and go home n start hacking.
Post by jsa » Fri Jan 01, 2021 11:47 pm
baba_banana
Post by baba_banana » Sat Jan 02, 2021 12:00 am
Cool will check it out later..
I’ve seen a post on ForScan where the person modified the tool to use MS-CAN. I don’t know how it’s related to 24V but I see in another post that 2004 onwards use that as auxiliary protocol to CAN.
So perhaps some modules might be excluded.. as I’ve seen on a post where the OP is trying to DIY for his diesel.
baba_banana
Post by baba_banana » Sat Jan 02, 2021 12:13 am
jsa wrote: ↑Fri Jan 01, 2021 11:21 pm ELM327's are a bit of hit and miss affair to get a real one.
How would one do dat actually? Step down the 24V? Is it a complex task?
Post by jsa » Sat Jan 02, 2021 12:27 am
12V or 24V for power supply, the chips are 5V I believe.
The data streams are a mix of voltages depending on which protocol standard.
Check out the documents on the Elm site.
Post by motorhead1991 » Sat Jan 02, 2021 1:39 am
baba_banana wrote: ↑Fri Jan 01, 2021 10:55 pm Oh lol.
Yeah man, there's some neat stuff here around Boise. Just let me know :grin:
baba_banana
Post by baba_banana » Sat Jan 02, 2021 5:01 pm
jsa wrote: ↑Sat Jan 02, 2021 12:27 am 12V or 24V for power supply, the chips are 5V I believe.
Ok yea. I actually have no clue how Bluetooth adapters get their power from. It probably makes sense that it taps the power from the port and on the modded Chinese adapter there’s a switch to go MS-CAN..
I figure I’ll order the obdlink Mx+ and also the cheap Chinese elm327 to open it up and take a look
baba_banana
Post by baba_banana » Sat Jan 02, 2021 5:07 pm
motorhead1991 wrote: ↑Sat Jan 02, 2021 1:39 am
Thanks. I’ve weighed my options and realized I’m severely lacking in options (both in a scan tool and also knowledge) of the vehicles I should consider. . I Guess imma head back down to San Diego and get everything figured out before I make waves in the market!
Was a great experience riding alone for 19hrs thou! Lots to think about and also shop at truck stops! Didn’t realize how much I miss having a ride!!
Anyways if u know of any deals on those big ass mofos, gimme a shoutout! I might consider a 4Runner for reliability too but I’m sure I’ll be more well prepared when I enter the market again!
teal95
Post by teal95 » Thu May 06, 2021 10:57 am
Going back a few steps M0M2 should have OBD-I which would be an output datastream from the EEC.
steve
'95 GT - T4M0 x2
'93 notch - A9P
'87 TC - 8UA or LB2 or LA3
'84, '85.5 & '86 SVO - PE
'83 & '84 GT turbo - TA x2
baba_banana
Post by baba_banana » Wed Jul 14, 2021 2:46 pm
Thanks for the help guys.
This is a pretty cool project but I’ve been busy searching for a job and it doesn’t seem like I’m gonna get into automobiles engineering anytime soon.. even thou programming dashboard user interface apps might be a dope job.
Anyways my math degree don’t provide me with any solid skills other than data analytics so I’m heading up to Seattle for an assoc in web dev to see if I can make shit happen.
Thanks for being kind n awesome guys. Hope everything’s going swell.
