fast1992us
Will not datalog and I followed the FAQ directions, A9L
Post by fast1992us » Wed Jun 11, 2003 9:53 pm
A9L and version 1.20B3
After reclocking the MAF and making a few caledit adjustments, the engine fired up more easily and idled on its own finally.
Before I started her up, I followed Jon's FAQ directions on how to datalog. At first I turned the key on then plugged in the USB cable, opened Caledit, checked my stuff, hit Payload, went to input/output, checked datalog, wrote the file to the tweecer, it did take, closed caledit, opened calcon, checked log to file, set the RT method to Fox (A9L computer, 92 LX), then I hit start logging but did not start the car. i wanted to see what the TPS was at. No logging, so I hit stop logging, started the car, and hit start logging again and some error screen popped up saying "Table does not exist...File C:Program Files\STKR\LogFiles..." and a string of numbers.
So I turned the car off, and redid the payload and everything as per the directions. Then I turned the key on, waited more than a few seconds, uploaded the file, it took, started the car, tried to log and the same error message popped up.
What am I doing wrong and what do I have to do to fix it?
Thanks.
A9L, v1.20B3
MY SIG/SITE
gt90stang
Post by gt90stang » Thu Jun 12, 2003 3:03 pm
Some of the variables give wierd errors.
Try these for starters:
http://tweecer.oplnk.net/viewtopic.php? ... highlight=
These work for me.
Don
fast1992us
Post by fast1992us » Thu Jun 12, 2003 4:10 pm
Do you know what that error message means? BTW thanks for the reply.
Do you think I should start over with a "clean" A9L file and redo the payload? Correct that positions 1-4 can datalog and 5 is the bypass?
Sorry for the multiquestions, but to upload a new cal to the positions, is it required that I Read EEC first, or can I just write to the Tweecer from the start?
Thanks again.
A9L, v1.20B3
MY SIG/SITE
fast1992us
Post by fast1992us » Thu Jun 12, 2003 5:35 pm
BTW the calcon real time light never went on, just the Tweecer RT green light was lit.
I made a fresh file and am going to set up the payload with the values you recommended. It's idling so rich my eyes burn. I'd really like to start datalogging to get the idle under control.
UPDATE: I uploaded the new "fresh" file, it took. Is the fuel pump supposed to kick on when uploading a Tweecer file? I recall my LPT Tweecer did that but this RT does not. The pump only kicks on when I Read EEC.
Anyway, I got the same DAMN error message "table not...". So, I unchecked the log to file box, and the Real Time light started blinking, but nothing popped up on the screen in either digital or analog displays. This was while the car was running. Also, when I got that error message, when I hit the stop datalog button it would not change to start datalog. I would have to close calcon altogether and restart it.
I did take the car out for a cruise after leaning the MAF curve 6% for the first 6 boxes. It idles a little better, not as rich smelling, and off idle wasn't too bad. It did buck some off idle and it surged a little at cruising. I half throttled it to about 4000 and it felt like it was popping or breaking up a little.
I wish I could get the datalogging to work so I can set everything up properly.
A9L, v1.20B3
MY SIG/SITE
gt90stang
Post by gt90stang » Thu Jun 12, 2003 8:47 pm
I get best results by making a payload, writing to Tweecer RT with the little datalog box checked and after it is done turning off the key for at least a few seconds. Then turn on the key, start CalCon and start logging....then start the car. Also you can't have CalCon loaded and make changes with CalEdit, it gives an error everytime for me.
#5 is bypass and I think can't datalog....never tried it.
Don't know what the error messages mean other than it ain't happy and don't work when you get one!
Good Luck, Don
fast1992us
Post by fast1992us » Thu Jun 12, 2003 9:25 pm
Thanks for the help Don. I will try what you suggested as soon as the laptop battery recharges. Perhaps once I get into a groove with the datalogging this won't be so frustrating, but I thought the datalogging part was easy to operate. I did not have calcon open the same time as caledit.
A9L, v1.20B3
MY SIG/SITE
93notch
Post by 93notch » Fri Jun 13, 2003 10:18 am
fast1992us wrote:Thanks for the help Don. I will try what you suggested as soon as the laptop battery recharges. Perhaps once I get into a groove with the datalogging this won't be so frustrating, but I thought the datalogging part was easy to operate. I did not have calcon open the same time as caledit.
Hey Rich,
Sorry your having a PITA getting this going, it sounds as if you are following all the steps. One question, did you uninstall the older version of caledit, etc or did you install over it? Also, read your CCF back from the tweecer with the payload loaded and I will check and make sure that it is getting written to the tweecer correctly. Finally, include the board rev when you send me the CCF.
Best regards,
Mike Glover
fast1992us
Post by fast1992us » Fri Jun 13, 2003 2:00 pm
Hey Mike, thanks for the reply. I sold that other laptop with the LPT Tweecer I had. This laptop is a new/used Dell running 98SE.
Okay, so I will Read Tweecer, and send you the file that comes out. I will include the board rev. with the file. I'll send it to the email address in your sig. You'll have it in an hour or so. Thanks again.
A9L, v1.20B3
MY SIG/SITE
fast1992us
Post by fast1992us » Fri Jun 13, 2003 3:16 pm
WoooHOOOO, it works! Some helpful person on the yahoo group told me to check the Logfile file to see if the "logfile.dbf" file was there. It was not. I reinstalled the Caledit/Calcon software from the CD and Yeehaw it datalogs. Hehe, this datalogger is cool as sh!^!
Here is the link to the first datalog:
www.ixpres.com/scubarick/030613154311.DBF
The KAMF was pretty low at around .94 and the IAC was at .54%, so I guess that means 54%. Once the engine temp hit 170 the KAMF came alive and the spark timing settled a little but kept bouncing between 19-22*. Now I have to recheck fuel pressure, base timing, and reset the throttle position and set up the idle and part throttle as indicated in that post by 86GT.
A9L, v1.20B3
MY SIG/SITE
klondike93
Post by klondike93 » Fri Jun 13, 2003 6:12 pm
That would have been me I believe, glad it worked for you.
Klondike (aka Chuck)
2003 Mach 1 DSG
94GT - sold
Users browsing this forum: Bing [Bot] and 35 guests
