Oldman
Adjusting A/F EEC-IV blower
Post by Oldman » Fri May 29, 2009 4:05 pm
I have an 89LX with F cam, headers, V3 blower, TFS TW heads, TFS intake, 30lb injectors, big pump, and Sunnit MAF for 30 lb injectors. I have a wideband O2 and recording device. Only 7-8 PSI boost max.
With MAF adjusted for calibration and injectors set for 30 lbs AFR is about perfect above 5000, but gets the following WOT curve:
3500 9.2
4000 9.3
4500 9.0
5000 8.8
5500 12.25
6000 12.8
6500 13
What is the best way to handle this in an EEC-IV? Change the WOT (open loop) fuel multipler table??
Tom
Oldman
Re: Adjusting A/F EEC-IV blower
Post by Oldman » Sat May 30, 2009 5:08 pm
Oldman wrote:I have an 89LX with F cam, headers, V3 blower, TFS TW heads, TFS intake, 30lb injectors, big pump, and Sunnit MAF for 30 lb injectors. I have a wideband O2 and recording device. Only 7-8 PSI boost max.
3500 9.2
4000 9.3
4500 9.0
5000 8.8
5500 12.25
6000 12.8
6500 13
Tom
Can anyone help with this?? Is the WOT fuel multiplier table the one to change to adjust fuel at lower RPM??
ami2loud
Post by ami2loud » Thu Jun 04, 2009 4:42 pm
im having a similar issue and have yet to get the Tweecer to correct the AFR at high rpm and full boost. Im not sure which parameters to modify and correct the lean condition.
87 Mustang GT
351W, S475 turbo, TFS heads, Victor EFI, C4, A9L GUFB w/ Tweecer RT, BE EA, A1000, 72lb inj w/ PMAS MAF
Oldman
Post by Oldman » Thu Jun 04, 2009 6:12 pm
ami2loud wrote:im having a similar issue and have yet to get the Tweecer to correct the AFR at high rpm and full boost. Im not sure which parameters to modify and correct the lean condition.
I'm having problems understanding the functions because they aren't described as fully as I need in the manual. I also can't seem to get a good dialog going with anyone who wants to "Elmer" first time tuners in how everything interacts.
From what I understand much of it is setting the MAS curve to correct A/F ratio. As I play with my Tweecer and learn (slowly on my own) I'd be happy to share, with the caution I am just learning. :-)
What MAS did you use? I assume you corrected everything with injectors and have the right curve?
Someone suggested I change the load scaling and RPM in functions. The tweecer manual on page 26 describes "load" but does not explain what changing the scaling actually does, so I guess it has to be by experiment.
I thought I could cheat the system and use more displacement to make up for the blower, but I was criticized for that so it must have been a bad idea. :-) If you find any beginners help please let me know!
Tom
DrDirt
Post by DrDirt » Thu Jun 04, 2009 8:32 pm
Actually, I would say you're rich at 5000 and below and pretty crispy above that. An AFR of 12.8 or 13.0 is good for NA but not for boost. I would set the WOT multipliers to 1 and set your desired AFR in the fuel table. That way you're not trying to juggle a target and a multiplier to come up with your target. Just set your target in the fuel table and adjust the MAF curve where necessary to hit the target. I shoot for 11.44 everywhere in WOT.
POPSRACING
Professional Tuner/Shop Owner
Post by POPSRACING » Fri Jun 05, 2009 8:32 am
DrDirt wrote:Actually, I would say you're rich at 5000 and below and pretty crispy above that. An AFR of 12.8 or 13.0 is good for NA but not for boost. I would set the WOT multipliers and set your desired AFR in the fuel table. That way you're not trying to juggle a target and a multiplier to come up with your target. Just set your target in the fuel table and adjust the MAF curve where necessary to hit the target. I shoot for 11.44 everywhere in WOT.
Set WOT functiion multipliers to "1" as this will disallow enrchmen or enleanment based off of WOT and RPM.
-Disable adaptive learning
--Set your adaptive max to 0.5 and adaptive min to 0.5
--Set adaptive min act to 10 and max to 20
-Set stabilized openlop table to tarket AFR 12.5 for NA base
-Datalog MAF voltage and AFR
-If there is a cell that is 13.2 at 5k and commanded AFT is 12.5 utilized the following equation
--13.2/12.5=1.056 then take the airflow at the given voltage and multiply is by 1.056
Land and Sea chassis dyno
1995 Cobra, 408, sold...
95rooster
Post by 95rooster » Fri Jun 05, 2009 5:07 pm
i would enrich whole table and the lean out the bottom end ie work backwords so your safer under boost or increase fuel pressure and then lean out low end of table.
95GT T4M0 EEC 92 block gt40x heads 1.72 rockers stock cam edelbrock rpm intake no smog no ac no egr 75mm tb incon tt 600 twin turbo kit with proflow maf pre cal to 30s/c 42lb fms injectors accufab 1to1 afpr plx m-500 wideband o2 with datalogger t-56 custom clutch aluminum flywheel and driveshaft 2.73 gears 315/40/17 nitto drags tuning with tweecer R/T currently testing out j4j1 tunes
DrDirt
Post by DrDirt » Sat Jun 06, 2009 10:16 am
Thanks, Pops. I intended to say set the WOT multipliers to "1" but I must have done some editing and deleted that part accidentally. I edited my post to include that so the waters aren't muddied.
Oldman
Post by Oldman » Sat Jun 06, 2009 8:30 pm
Already done
Calibration editor won't do that. I set both to .5 in calibration editor and it changes itself back to 1
Done
Do you mean "fuel table-base open loop" ?? I'm using calibration editor V1.30
Tom
POPSRACING
Post by POPSRACING » Sun Jun 07, 2009 5:00 am
In caledit set adaptive control min and max to 0.5 and 0.5 then click refresh button on bottom right corner, if .5 is entered it won't take the change.
Set Act for maximum control min to 10 degrees and max to 20 degrees.
Yes, set Fuel base ol
What version and strategy of caledit?
Oldman
Post by Oldman » Sun Jun 07, 2009 8:46 am
Thanks for the help Pops. The documentation is pretty poor, so I have to relay on help. I was told by another expert to read the manual, but there is no manual or help for CalCon and limited info for CalEdit.
POPSRACING wrote:In caledit set adaptive control min and max to 0.5 and 0.5 then click refresh button on bottom right corner, if .5 is entered it won't take the change.
Won't take the change. It will take 1 and 1, but not .5 and .5
Done. Easy.
v 1.30 and strat A9L
dustang83
Post by dustang83 » Mon Jun 08, 2009 1:45 pm
He was trying to say to type in "0.5" not ".5" It may make a difference
'79 Fairmont Futura
Stock 120k '90 EFI 5.0L, Novi 1K @ 5psi, UPR PP, GT40Ps, HO Cam, Performer, 42lb, 255lph, FPR, LTs>Single 3", 70TB, 76mm C&L w/Blue Tube, No AC/PS/Smog, 3.73, Stock AOD w/Baumann SK, A9P w/Tweecer RT/EA/BE/AEM WB 14.1@100MPH (N/A)
DYNO
Post by DYNO » Mon Jun 08, 2009 2:45 pm
For me the best way was to get the right AFR at WOT N/A. I have done that buy sizing the injector slop, and tuning the maf curve, after that a have use the W/O FUEL MULTIPLYER to get the AFR i looking for under boost. Sorry for my poor english
1992 lx, stock 2001 explorer engine, ARP head stud, holley 255 in thank, 42lbs, A9L, RT, HOLSET turbo, blow trow mass air 90mm ford unit in 3in pipe, lakwood belhosing, tko 600, frame connector, 3.73, QA1 cross member + coil over, and more.
Oldman
Post by Oldman » Wed Jun 10, 2009 8:48 am
Thanks all. The biggest problem I had were the poor or missing manuals and lack of reference documentation. This, and the lack of serious Elmering by people who claim to have it all figured out, is what really slowed the learning curve down.
I have things working now although not exactly by planning. Some of it was experimenting or cut and try. The constructive suggestions that filled in areas where the documentation is missing were greatly appreciated!!!
Tom
Users browsing this forum: No registered users and 123 guests
