mnhaught
How to read Dissassembly
Post by mnhaught » Wed Sep 30, 2009 6:13 pm
Hi,
I was wondering if someone could tell me how to read a dissassembly? I have the CAT's running right now, but I just don't understand what I'm looking at.
Would someone please help?
Marshall
94 f150 4x4 strategy is CBAZ0,Trans 4R70W,Flowmaster 40 series exhaust, BBK shorty headers ProM 75mm, K&N cold air filter, 302 bored .020 over,ZL2482F Speed Pro pistons, 165 AFR heads, XE258HR CompCams, Ford racing 30lb injectors. LM-1 WB. I have EA and BE,CBAZ0.CRY, Tweecer RT.
svojohn
Re: How to read Dissassembly
Post by svojohn » Mon Nov 16, 2009 9:38 pm
Can you post a screen capture of the code you're trying to read?
mnhaught
Post by mnhaught » Wed Nov 18, 2009 7:00 pm
Sure, The binary is from the HUG2 PCM. For example, I know that at the address B8FE is the start of the MAF transfer function, but how does one know that for sure?
B8FE: FF NOP ;.
B8FF: FF NOP ;.
B900: DC 09 JVT LB90B ;..
B902: 00 SKP ;.
B903: 50 DC 09 00 AN3B ZROLO,INTPND,L00DC ;P...
B907: 4C **** ;Address Alignment Error
B908: 7B 08 00 48 SB2B L0048,ZROLO[INTMSK] ;{..H
LB90B
B90C: 3D 07 00 JB TMRHI,5,LB90F ;=..
B90F: 44 26 06 00 LB90F AD3W ZROLO,TMRLO,L0026 ;D&..
B913: 40 **** ;Address Alignment Error
B914: 30 05 00 JNB AD_HI,0,LB917 ;0..
LB916
B917: 3C 59 04 LB917 JB L0059,4,LB91E ;<Y.
B91A: 00 SKP ;.
B91B: 38 9D 03 JB L009D,0,LB921 ;8..
B91E: 00 LB91E SKP ;.
B91F: 34 FA 02 JNB L00FA,4,LB924 ;4..
LB921
B922: 00 SKP ;.
B923: 30 6E 02 JNB L006E,0,LB928 ;0n.
LB924
B926: CD **** ;.
B927: 2C 0C SCALL LB535 ;,.
LB928
B929: 02 9A CPLW L009A ;..
B92B: 29 B6 SCALL LBAE3 ;).
B92D: 01 66 CLRW L0066 ;.f
B92F: 26 6C SJMP LB79D ;&l
B931: 01 **** ;Address Alignment Error
B932: 33 23 2B JNB L0023,3,LB960 ;3#+
B935: 01 9A CLRW L009A ;..
B937: 21 0E SJMP LBA47 ;!.
svojohn
Post by svojohn » Wed Nov 18, 2009 11:41 pm
Try looking up the Calibration_Pointers at 0x2022 through 0x2030 as a word. This will tell you the address of REG_F0 through REG_FE.
Example code:
2022  00C0                word  $C000                       ; REG_F0
2024  ECC2                word  $C2EC                       ; REG_F2
2026  C6C4                word  $C4C6                       ; REG_F4
2028  EACB                word  $CBEA                       ; REG_F6
202A  4ECE                word  $CE4E                       ; REG_F8
202C  12D4                word  $D412                       ; REG_FA
202E  C2D6                word  $D6C2                       ; REG_FC
2030  D6D6                word  $D6D6                       ; REG_FE
Notice throughout your code you'll see code which looks similar to this:
21B5  452A00F042            add   REG_42,REG_F0,#$002A
The code will add 002A and REG_F0 together to find the lookup address. REG_F0 equals C000 in the above example code. C000 + 002A = C02A which just happens to be the MAF transfer function in my example code.
mnhaught
Post by mnhaught » Thu Nov 19, 2009 10:36 pm
I think I am following you so far. I think I found the pointers, but the Cat's dissassembler doesn't show the registers like the the code you posted. Unless I am doing something wrong, which is possible.
The pointers I found are as follows:
E4D8
FADA
CCDC
74E6
F8E9
58EF
30F2
88FD
I have to reverse the bytes to get the addresses for the registers. Is that right?
svojohn
Post by svojohn » Fri Nov 20, 2009 8:53 am
I'm not familiar with the Cat's disassembler. I use the 8061 disassembler by William Lawrance. This disassembler requires you to make a DIR file for the code you're working with.
Yes your F0 equals D8E4 and so on...
mnhaught
Post by mnhaught » Thu Nov 26, 2009 8:04 am
svojohn wrote:Try looking up the Calibration_Pointers at 0x2022 through 0x2030 as a word. This will tell you the address of REG_F0 through REG_FE.
Example code:
I think I understand what your saying, but how did you know 21B5 would be the MAF transfer function?
How does a DIR file work :confused: ?
Thank you for taking time to help me understand all of this stuff.
svojohn
Post by svojohn » Fri Nov 27, 2009 9:03 am
I use Microsoft Word to make my DIR file. The disassembler will use the DIR file to add comments, labels and display code as hex, byte, word, code, etc... Here's an example of my DIR file for the code above:
commentl    2021  Num_Calibs
hex         2021
commentl    2022  Calibration_ptrs
word        2022
comment     2022  REG_F0
comment     2024  REG_F2
comment     2026  REG_F4
comment     2028  REG_F6
comment     202A  REG_F8
comment     202C  REG_FA
comment     202E  REG_FC
comment     2030  REG_FE
commentl    2032  ************************************
commentl    2032  * Reset Subroutine
code        2032
21B5 is not the MAF transfer function, C02A is the MAF transfer function. Knowing that requires you to go through the code and figure it out. All the mass air eec-iv's will have code that looks similar to this somewhere in the code:
         ; * Read MAF/Calibrate/Lookup in Transfer Function
5C8D  A372A050      L5C8D ld    REG_50,$A0[REG_72]          ; $0120 = raw MAF counts (voltage)
5C91  6D002850            mulu  REG_50,#$2800               ; max calibrated count
5C95  8F728E              divu  REG_50,$8E[REG_72]          ; $010E = div by zero (VCAL) regulated
Looking through here you'll find code which looks similar to this:
5CA2  A376D252            ld    REG_52,$D2[REG_76]          ; $0352 = MAF transfer function pointer
Now look back at 21B5 and we see this same pointer at 21BA getting loaded into C02A:
21B5  452A00F0            add   REG_42,REG_F0,#$002A        ; $C02A MAF transfer function
      42
21BA  A376D232            ld    REG_32,$D2[REG_76]          ; $0352 = MAF transfer function pointer
Users browsing this forum: No registered users and 41 guests
