xafalcon
RPM Flare-Up Neutral to Drive
Post by xafalcon » Fri Aug 13, 2010 9:42 pm
I have an annoying RPM flare-up when the NDS switches from a Neutral setting to a Drive setting. It makes the engine bang into gear which i would like to eliminate. When the engine is cold it flares up about 400RPM, but only about 100-150RPM when warm. The revs stay elevated for about 10 seconds if I trick the NDS into thinking I've put the auto into gear.
Now Since the RPM flare-up happens to a greater extent when cold, I've checked all the ECT related parameters without finding anything that looks likely. I've also checked idle and NDS related parameter but came up empty again.
The application is an Auzzie 5.0 with 1991 EEC4 ecu very similar to A9L/A9P.
Can anyone point me in the right direction so I can reduce this RPM flare-up.
1995 RHD Mustang running Australian EEC4 retro-fit 220kW 5.0 and BTR Transmission. Tuned using TunerPro and Binary Editor on Moates Quarterhorse.
Re: RPM Flare-Up Neutral to Drive
Post by decipha » Fri Aug 13, 2010 9:51 pm
go change the trans switch to forced neutral state
xafalcon
Post by xafalcon » Fri Aug 13, 2010 11:42 pm
The definition seems different from A9L here. There only seem to be 2 choices - 00 = manual, 01 = automatic. So should I switch to manual?
Post by decipha » Sat Aug 14, 2010 12:11 am
thats what i would do
xafalcon
Post by xafalcon » Sat Aug 14, 2010 7:11 pm
OK, I tried changing "Transmission Type" from Auto to Manual but it made no difference, I still get the rpm flare. Also tried increasing the "Time Delay Before N/D or D/N Switch Registers" from 0.25 seconds to 2.5 seconds. But this also had no effect.
Any other ideas much appreciated.
Post by decipha » Sat Aug 14, 2010 7:16 pm
well its not obviously not working in the tune so you might as well just ground out the nps that way you don't have to worry about it
Post by EDS50 » Sat Aug 14, 2010 8:04 pm
xafalcon wrote:The definition seems different from A9L here. There only seem to be 2 choices - 00 = manual, 01 = automatic. So should I switch to manual?
TRLOAD only has two choices in your definition? Interesting..
xafalcon
Post by xafalcon » Sun Aug 15, 2010 3:35 pm
As best as I can tell. I've dumped or otherwise obtained binaries from various Auzzie EEC4 V8 ecu's. Some auto, some manual. They all follow the trend 00 = manual, 01 = automatic.
The auto ecu's do have some VERY basic transmission related parameters (but no actual direct transmission control functions) as the transmission was a locally produced electronically controlled (by a seperate tcm) unit rather than the US AOD non-electronic transmission. There are two one-way data links between ecu and tcm, one in each direction. Ecu tells tcm about engine temp and A/C status (which effects shift points and converter lock-up under certain conditions). Tcm tells ecu about reverse gear selection and transmission LOS (both invoke torque reduction).
I have not tried inputting numbers other than 00 or 01. But it clearly doesn't follow the A9L style of coding for this parameter where 00 - 03 were manual trans and 04 - 06 were auto trans.
xafalcon
Post by xafalcon » Sun Aug 15, 2010 3:41 pm
decipha wrote:well its not obviously not working in the tune so you might as well just ground out the nps that way you don't have to worry about it
Thanks but I'd prefer not to do this. The starter inhibit is a safety feature that needs to work for our local 6 monthly vehicle safety inspections. And if my wife ever drives the car, it needs all the safety features posible. Otherwise it's likely to get all banged up when she starts it in gear and it moves off the mark.
Maybe an RPM switch with a switching point of 400RPM would be a safe way of doing it, but I'd much prefer to find the code that controls it and modify it the right way.
Post by decipha » Sun Aug 15, 2010 10:25 pm
you can still have a functioning nps just remove it from getting to the ecu, then just ground that pin from the ecu and all is taken care of ecu wise and everything functions as it should mechanically,
t'would' be nice to find that scalar in your tune but if you don't have that option then :cry:
can you post a log of when it does this, that's assuming you have some type of datalogging capabilities??
xafalcon
Post by xafalcon » Sun Aug 15, 2010 10:47 pm
Thanks decipha, but I currently have no data logging capability.
But I decided to have a try through modifying the ISC transfer function. As an initial rough test I scaled the mass flow (except first and last entries) by a factor of 2. On a warm engine it works great. Tomorrow I'll know what a cold start and drive-off goes like. If this is OK, I'll try and re-curve the ISC transfer only in the area where it causes this RPM flare.
Post by decipha » Mon Aug 16, 2010 8:48 pm
can you send me what you got and i'll take a look??
Users browsing this forum: Bing [Bot] and 118 guests
