TEMPLATES 101 - Start Your Tune Here
Collection of newbie questions and common tuning concepts
Locked
Post by decipha » Wed Nov 03, 2010 8:36 pm
A template is nothing more than a fast way of making a common change to a tune. Sometimes known as a 'value file'; a template can help prevent skipping over and missing a value.
This is a continuance of tuneXchange which was formed solemnly for the DIY tuning community headed by my good friend Wes Ratcliff.
This is a work in progress so expect templates to be added modified and updated often.
All CBAZA definition templates were created using sailorbob's def, if your using the junk free XLS cbaza def then these templates more than likely won't load correctly and will probably do some odd things to your tune if they don't error out completely, so be warned. Sailorbob's def can be had for next to nothing so it would be wise and highly recommended to get it, if not shame on you.
Post by decipha » Wed Nov 03, 2010 8:41 pm
Lock Idle Timing @ 30 degrees
Lock Idle Timing to 30.TXT
(1.64 KiB) Downloaded 2112 times
GUFB
makes the engine more efficient at idle
aids in throttle response
reduces timing to 20 degrees above 1500 rpm @ closed throttle which is useful for boosted engine if the tps ever fails :shock: (had it happen before) also stops backfires for timing spike on boosted engines
Non-Stock MAF
Post by decipha » Fri Nov 12, 2010 8:45 pm
Removes the stock maf clips for those with aftermarket maf's
prevents the ecu from disregarding the maf altogether if the idle voltage is below the stock value
Non-Stock MAF.TXT
(2.82 KiB) Downloaded 1924 times
GUFB
Long Tube Headers
Post by decipha » Fri Nov 12, 2010 9:14 pm
adjusts closed loop to work correctly with long tubes
Longtube Headers.TXT
(5.5 KiB) Downloaded 1838 times
GUFB
Lean C/L for Fuel Economy
Post by decipha » Sat Nov 13, 2010 12:48 am
Lean Closed Loop for Fuel Economy
Average Lambda ~1.05 (AFR ~15.4 for gasoline) during closed loop at idle and cruise
Lean CL.TXT
(4.4 KiB) Downloaded 1397 times
CBAZA
do not load this template unless your fueling is dialed in else it could cause sputtering from being too lean
80# Injectors
Post by decipha » Wed Nov 17, 2010 12:30 am
Ford & Siemens Deka High Impedance 80# Injector values
since the new version of BE doesn't allow more than one strat in a template, here's two
GUFB
80# injectors-GUFB.TXT
(1023 Bytes) Downloaded 1115 times
CBAZA
80# injectors-CBAZA.TXT
(922 Bytes) Downloaded 961 times
also included is the ford pdf for the injector values
80 lb injectors.pdf
(13.5 KiB) Downloaded 1069 times
1 HEGO and LEAN CL
Post by decipha » Fri Nov 19, 2010 1:12 am
1 HEGO and Lean Closed Loop
GUFB
1 HEGO and Lean CL.TXT
(6.14 KiB) Downloaded 1096 times
useful for those with 1 hego or for those that have turbo setups, also bias's the hego lean right around ~1.05 lambda (~15.3 AFR for gasoline)
improves fuel economy
improves throttle response
decreases fuel odors for lapping cams
REMEMBER... you can only use hego1 the passenger side
if you have trouble with this which you shouldn't but if you do set the hego bias table to all 0s to richen her back up to stoich
Re: TEMPLATES 101 - Start Your Tune Here
Post by EDS50 » Sat Feb 26, 2011 11:13 am
GUFB/A9L FRPP M-9593-A302 LIGHT BLUE TOP EV1 24# Injector Settings
m-9593-a302 24#.pdf
(17.09 KiB) Downloaded 975 times
Post by EDS50 » Tue Apr 19, 2011 12:12 pm
GUFB/A9L FRPP M-9593-B302 EV1 30# Injector Settings (RedTop)
m-9593-b302 30#.pdf
(17.09 KiB) Downloaded 831 times
Post by EDS50 » Tue Sep 20, 2011 11:55 am
GUFB/A9L FRPP M-9593-BB302 EV6- 30# Injector Template as Provided By NotchAbove
30# Motorsport injector BB302.TXT
(1.47 KiB) Downloaded 1066 times
Post by EDS50 » Thu May 03, 2012 1:59 pm
GUFB/A9L FRPP GREEN TOP INJECTOR SETTINGS
m-9593-f302 42#.pdf
(13.48 KiB) Downloaded 604 times
Post by EDS50 » Thu May 03, 2012 2:10 pm
GUFB/A9L 90MM LMAF MAF CURVE
Post by EDS50 » Thu May 03, 2012 2:51 pm
GUFB/A9L - STOCK A9L.BIN WITH FN1360
NOTES:
This is not a template, this a 56k .bin calibration.
Stock a9l.bin with fn1360 patch code and table data applied properly. It is disabled by default. I left it disabled because you the user will need to determine whether you want it "enabled" or "enabled with no WRMEGO check".
STOCK A9L.BIN-FN1360 APPLIED.BIN
(56 KiB) Downloaded 846 times
Post by EDS50 » Thu May 03, 2012 3:03 pm
GUFB/A9L A9L - Z_KAMCLR
Notes:
This is not a template. This is a stock A9L 56k .bin with Z_KAMCLR enabled.
When you want to clear the kamrfs of any learned fuel trims; you can write this tune to the hardware with the key off engine off. Once written to the hardware cycle the key on and off 3 times. With the key off load your current tune or tune you want to use and the kamrfs and any learned fuel trims will be cleared.
A9L-Z_KAMCLR.BIN
(56 KiB) Downloaded 547 times
Locked
