need btc0.bin - cmba0 strat 98 lincoln mark VIII
Post by decipha » Fri Feb 04, 2011 9:59 pm
i made a cmba0 strategy for BE but i don't have a bin
AFAIK, the only bin for the cmba0 strat is btc0 only for the 98 mark 8 ??
if anyone has it or knows where i can get it, please send it to my email and post it here
thanks in advance
ClintD
Re: need btc0.bin - cmba0 strat 98 lincoln mark VIII
Post by ClintD » Sat Feb 05, 2011 1:46 am
I'll get you a bin this weekend.
74 Ford E100, 5.0 Explorer engine with AOD transmission and is now carbureted.
1987 Mercury Cougar XR7, T5 swapped and currently in the process of HO swap
2014 Harley Davidson FLHXS.
2003 GMC Sierra 3500 6.6 Duramax untouched and used to tow anything I blow up back home.
ASE Master Technician and Advanced Level Specialist.
It's not what I know, It's knowing what I don't know.
ClintD
Post by ClintD » Sat Feb 05, 2011 10:18 pm
this is off of the chip. are you going to be selling the strat when you figure it out?
Post by decipha » Sun Feb 06, 2011 7:58 pm
nope, it'll be an xls open to the public, just like chris grey prefers
im pretty much done with it just need to check this bin and i'll post it
i got about 18hrs straight invested in it, and i made it solemnly just to help you and mike out, so i expect a huge thank you in the end
Post by decipha » Sun Feb 06, 2011 8:08 pm
quick question
how do you get a 56k bin from a 2 or 4 bank ecu ?
IE it doesn't work
EFI-Unlimited
Professional Tuner/Shop Owner
Post by EFI-Unlimited » Sun Feb 06, 2011 9:33 pm
decipha wrote:i made a cmba0 strategy for BE but i don't have a bin
thanks in advance
How do you make a DEF without a BIN? Pilfering another source of DEF data?
BTC0 ad MLX0 are the only cal's that use this strat.
Brian
EFI-Unlimited
Post by decipha » Mon Feb 07, 2011 9:24 pm
yep just copying memory locations and trying to figure what the hex conversion to decimal is
worked out pretty well on most of them, i got a few i made thus far
ClintD
Post by ClintD » Wed Feb 09, 2011 1:54 am
I'll check and see if I copied it wrong.
ClintD
Post by ClintD » Wed Feb 09, 2011 2:12 am
how do I copy this. everytime I do its only 56k
Post by decipha » Mon Feb 14, 2011 8:32 pm
thats cuz your using a single bank def to read it
use this def read the chip and post it
Cougar281
Post by Cougar281 » Sat Oct 15, 2011 5:46 pm
Decipha, did you ever finish this? I'm going to be looking for a motor out of a 97/98 Mark VIII to drop into my Cougar, and when that time comes, I'd like to have a Mark tune to look at as a baseline to try and get the motor running better than on a 04 Mustang tune. Also, just an FYI, MLX0 is also a CMBA0 catch code (also found in the 98 Mark). Looks like there were about 7 different strategies used in the 97 Mark :shock:.
1995 Mercury Cougar XR7 -
  • 2002 "Explorer" 4.6L V8
  • "Pink Top" F0TE-D9B Injectors
  • 2002 Mustang GT MAF
  • J-Modded 1999 Mustang GT 4R70W Trans
  • 22c Plugs
  • Cobra Radiator & Fan
  • 255LPH Fuel Pump
  • 180* T-Stat
  • 2004 Mustang GT PTP2 PCM
  • QH v1.6 & BE.
