car goes dead rich and cuts out for a second
does this sound like it could be a corrupt tune? I have attached the log, you can see where it goes dead rich for no reason.
this occurred while it was idling and the engine just cut out then came back to life.
in a seperate datalog, i saw my wideband go to 8.1 at idle all by itself
- Attachments
- 2011_Jun_12_13-59-12.csv
- (577.75 KiB) Downloaded 515 times
92 coupe
302, afr's, tfs 1 cam, gt40 intake, S trim, 42lb injectors,longtubes,pmas velocity, tweecer, lc1
Re: car goes dead rich and cuts out for a second
What I can tell you and it might not be of any real help but what is happening for a reason I can't see, but the Load is spiking, hitting almost 100. When this happens the lambse table changes and commands a real rich mixture. Since the car is not really under load, its going to stall.
Question of the day would be why does the load spike like that.
1993 Reef Blue Coupe
Thumper Ported E7's
Cobra Intake & 65mm TB
Crane 2031 w/1.7's
LMAF (02 Lightening Curve) Leaned out 5%
190 lph fuel pump
Kirban Fuel Regulator
A3M computer
EGR only, no Smog
10 degrees base timing
BBK 1 5/8 shorty headers
T5 Tranny 3:55 rear
Thumper Ported E7's
Crane 2031 w/1.7's
190 lph fuel pump
A3M computer
EGR only, no Smog
T5 Tranny 3:55 rear
I downloaded a new binary from the EA website, and put in my settings from the old tune.
I let it idle and it appeared the problem was gone. So I'm hoping it was just a corrupt tune.
Thanks for looking at the log NotchAbove.
92 coupe
i went to drive it today, let it idle, same issue :headbang:
before starting it I made some small adjustments to the tune, that was it
anybody have any ideas? It doesnt seem to do it in the stock tune position
92 coupe
Please someone help!!!
Im getting very bizarre and inconsistent problems. The car goes rich for no reason, sometimes it stalls out(i was driving on the highway and it just shut off), once time it would cut out whenever i hit the gas enough to invoke CL. I didnt have this problem last year.
I have tried another computer, another tweecer, cleaned the j3, cleaned my 10 pins, and added a ground from the chassis to where the battery cable goes to the block. I have tried fresh binaries and a million different tunes. I also tried another TFI I had laying around, and pulled codes and found nothing.
I had a problem with BE auto updating when i first launched it this spring, I can read and write to the tweecer ok, I am wondering though if it is corrupting the tune somehow? Or if it is electrical?
I've tried to troubleshoot this logically but am starting to lose my mind. I have attached another different datalog, you can see where it goes crazy around 507.2818.
Any insight would be very appreciated.
- Attachments
- 2011_Jun_28_17-07-12.csv
- (1.55 MiB) Downloaded 476 times
92 coupe
That is weird. It kind of looks like the ECM is loosing power.
Isn't there some wiring and a fuse near the battery that supplies power to the ECM? I would double check all wiring.
1986 Mustang GT - A9L w/ Quarter Horse and LC-1 Wide Band, Scat 331 Bored . 040, Edelbrock Performer heads (10.2/1 CR), Edelbrock Performer Intake, BBK 70mm TB, Comp Cams XE270HR-14 cam, Crane Gold Race 1.6 Rockers, Ford Racing 42lb injectors, C&L 80mm (green tube) MAF, Astro Performance T-5.
the odd thing is that it doesnt do it on a stock tune. That is how I was able to get an inspection sticker for the car. I drove it there on the stock tune.
:headbang:
:headbang:
92 coupe
Sounds like its time to download crossloop and let someone dial in to help you out.
2003 Mach 1 - Core Tuning RYAK1/ZYA2 QH Tuned, Borla Atak Cat Back, Pypes X-Pipe, Twin 65mm TB, K&N CAI, ICT Billet Intake Spacer, Eibach Pro Series Plus Suspension, Steeda Adj. Upper/Lower Control Arms, QA1 Bump Steer, Steeda Short Throw Shifter, 315/35/17's.
Could also be a bad fuel pump or eec relay. But maybe not likely since you say she runs fine with the stock tune.
Yeah, i added that to my word document of things to check out. But it just doesnt seem to make sense.
I have searched on many posts trying to find what the issues were to odd problems.
I imaged my laptop back to last summer when I didnt have this problem so I am going to try that next.
Does adding the tweecer to the computer impact any other part of the wiring/electrical that might not show up when the computer is running by itself?
92 coupe
Does your MAF volts start with 0 at the bottom and 15.9998 at the top, if not it could cause issues like that. I had some strange problems due to those numbers.
Subscribing... I have had this,or similar issue as well,and is still an ongoing from time to time. The car will run fine for the most part,usually after,say... a short blast,it will run like crap...like it is trying to relearn itself (adaptives disabled),you can continue to drive,but it will die on declutch.Now if you turn off ign and restart all is well, most of the time I just rewrite the tune,this appears to work for awhile.
I havent figured this out yet, but am all ears...(eyes) I also use a Tweecer, I have attached a log I caught while it was doing this,
- Attachments
- 2011_May_22_12-30-00.csv
- (88.11 KiB) Downloaded 436 times
82 Volvo 245,306 , Afr 205's,custom cam,Perf rpm2,90mm sct BA-2600,30lb injectors75mmTB,A9l/tweecerRt,BE/EA, 5spd
- EFI-Unlimited
Here's mine anyway...
- Attachments
- volvo2hiloslo1.75dload.BIN
- (56 KiB) Downloaded 457 times
My maf does start at 0 and end at 15.9998.
Brian, I am at work right now, I'll email that or post it up tonight. I have redone the tune so many times and it never seems to make a difference - with fresh binaries. But I will gladly accept your offer to look at it.
92 coupe
well that didnt do it, so i dont think it is the software.
I have posted some bins, it doesnt matter what I do screwy things happen.
- Attachments
- postimage.BIN
- (56 KiB) Downloaded 429 times
- post10pin.BIN
- (56 KiB) Downloaded 354 times
92 coupe
- EFI-Unlimited
Neither binary resolves as anything common, and they both appear to be different base images. Where did you get the base image for this? Was it a read, a download or what?
At the moment, it looks like it may be a corrupt image. Other than that, in postimage.bin the battery comp table has 15 as the top value in the left column. It needs to be 15.9375. That could cause the issues you are describing.
Brian
EFI-Unlimited
Brian
EFI-Unlimited
Thanks for taking the time to look Brian.
When the problems started, I tried fresh binaries from Clint's website, and also tried reading from the hardware.
Do you think it could be an electrical/sensor issue that doesnt manifest itself unless there is a tune on it?
It doesnt have the crazy issues on the stock tune, but it also doesnt run that great.
I am contemplating putting a stock maf on it just to see what happens. At this point I may just have to try different things.
92 coupe
I don't know why it's happening, but I suspect that the ECU is re-initializing itself (and one of a few reasons for that is power interruption).
I suspect that because your log just happens to capture ECT and ACT at 60, which is what they are initialized to.
GrnTrunk wrote:I've tried to troubleshoot this logically but am starting to lose my mind. I have attached another different datalog, you can see where it goes crazy around 507.2818.
I tried a lincoln 80mm maf I had, that didnt change anything though. I may have to take a break before I get committed.
92 coupe
i've never experienced anything like this before, too bad your not closer to new orleans (or wyoming for that matter)
I ran the ftdi uninstall and tweecer driver reinstall per the instructions in BE. It seemed to help but not totally cure the problem.
So, I am not sure if it really helped at all. Best I can figure perhaps the extra power draw from adding the tweecer is doing this.
I may try another relay at some point.
92 coupe
fp and eec relays are automatically replaced whenever a car comes to me with ANY intermittent issues what so ever
i don't care if its the friggin' windshield wipers acting up
I replaced the eec relay yesterday and drove it an hour without it seeming to do it. I datalogged it to verify but for some reason the logs were not on the computer so I couldnt verify in EA. I am hopeful that has fixed the issue.
92 coupe
i think the relay fixed it. i have put 300 miles on the car since then and it hasn't done it.
so weird that the problem didnt exist until the tweecer was added. i can only assume it was the extra power draw.
92 coupe
