slosvo
JOY or no JOY
Post by slosvo » Thu Nov 17, 2011 5:52 pm
Hey fellas, sorry to bug with another idiotic noob question.. Looking through the stratagy XLS sheet, from what I researched there is no support for the JOY0 calibration of a SD 95 Bronco?
if so recommendations?? repin to a a9l??
thanks again
Alex :crazy:
86 SVO- 2.3T C-4 54lbs injectors 27 psi and 150 dry shot= hole in piston- EEC tuner PCMX tuned- attempted tune..
85 Saleen #111, in process of EFI A9L swap and single turbo- QH BE EA
03 Mach 1 T56 4.56 150 wet shot- SCT xcal3
04 Mystic termee, bolt ons- Sniper Tuned
Re: JOY or no JOY
Post by decipha » Thu Nov 17, 2011 6:09 pm
what strategy is joyo? I thought the bronco's are either cbaz0 or ahac strategy both of which are well broken out
in any case i wouldn't go with the guf ecu, if your going to swap ecu's at least go with something newer, even a cbaza from a 94-95 mustang would be an improvement, so much more control
slosvo
Re: JOY or no JOY
Post by slosvo » Thu Nov 17, 2011 6:17 pm
in the XLS file the JOY0 calibration shows a XXX for a stratagy.. I do know the bronco is speed density.. guess the trucks didn't go MAF till 96?
on a side note: i just got a call from a buddy of a buddy asking to see if i would tune his blown 94-95 GT.. I have never played with those.. time to get my feet wet.. i do recall everyone running from that era PCM.. guess times have changed.. is Popsracing the def/template to use?
Re: JOY or no JOY
Post by decipha » Thu Nov 17, 2011 7:02 pm
yeah times have changed, now that more people have the ability to reprogram them they are more desireable
a def and a template are two different things, a def file is either an xls or a cry file that correlates memory locations and values to more conventional values
a template is just a txt file with calibration values that overwrite your current calibration values, such as injector values or maf transfers
popsracing offers strategy files for almost all 80s-2004+ fords, they offer 1 of the 3 cbaza definition files too
Re: JOY or no JOY
Post by sailorbob » Fri Nov 18, 2011 5:05 am
Post the JOY0 bin up, someone may recognise the strategy it uses.
slosvo
Re: JOY or no JOY
Post by slosvo » Fri Nov 18, 2011 1:07 pm
I don't have immediate access to that Bronco. the guy is like 2 hours away. The guy installed a 340hp crate 302.. which has a Alphabet cam in it and he swapped in some 24lbs.. needless to say it runs like poo.. I had forewarned that its either going to need a PCM swap and repining or stock cam and injectors put back in..
Re: JOY or no JOY
Post by decipha » Fri Nov 18, 2011 8:09 pm
19s aren't going to support 340hp, neither will 24s
he'll need at least 30s, might as well go 80s
