StangD
Ready to datalog the new 347, running BAD!
Post by StangD » Fri Sep 14, 2012 5:59 pm
Need a little help on where to start. Fired the new 347 and she is running real bad. Going to be a little tough to get a good datalog as it will not idle, could use a few tips on where to start. Popping out the pipes. Engine is running a base 347 TWEECER tune. About everything is new so can't rule out much yet but very likely it is the tune. Combo in my signature but running 90MM LMAF, 42# injectors. The cam is an FTI (Ed Curtis) and pretty rowdy as this is mostly a drag car. I am a fairly experienced engine builder so for the moment lets assume a piston isn't installed upside down OK? :biggrin: The TPS readings look OK. The 02s are reading about .1V or less at all times. MAF readings 1-2.5 volts as I am pumping the throttle to keep it runnng.
I'll be back on it in the morning after the neighbors are awake. This thing is loud as hell. Hoping for some tips on where to start looking. I'm guessing MAF data and injectors, but a guess is all it is at my tuning experience level.
94 GT-T5-347-CBAZA-TM40
QH-BE2012-Innovate LC-1
Re: Ready to datalog the new 347, running BAD!
Post by decipha » Fri Sep 14, 2012 6:17 pm
its obviously lean.. give it more fuel
StangD
Post by StangD » Fri Sep 14, 2012 6:40 pm
decipha wrote:its obviously lean.. give it more fuel
I also probably better verify I am running the engine long enough for O2s to give an intelligent reading before I post data on this board. Lean isn't what I initial impression was. Keeping it running isn't easy but I need get it into closed loop and am not certain I have yet.
Post by decipha » Fri Sep 14, 2012 7:43 pm
its easy enough to tell if an engines lean, just yank a plug and take a look see
StangD
Post by StangD » Sat Sep 15, 2012 1:46 pm
decipha wrote:its easy enough to tell if an engines lean, just yank a plug and take a look see
I accidentlally ran on the factory tune for a several minutes so the plugs were really sooted up. Car already running a little better today with only a few minutes run time on it. I will probably change the sparkplugs and see if that helps. I did datalog it in closed loop today and the O2s are in the .3 range.
StangD
Post by StangD » Tue Sep 25, 2012 6:01 pm
Got my BE 2012 up and running and making the switch from CALEDIT. It's easy to see the capabiities are incredible.
Didn't want to start a new thread but will if I should. Hoping somebody might be willing to look at my current tune. I've sent it to Adam at POPS but he's a busy guy. Here is where I am if somebody is willing to have a look. I puchased Adam's CBAZA strategy. I took a base 347 tune (bin file) from my TWEECER and updated a few things. Engine has zero miles on it and 20 minutes of rough running in the garage. Changes to base tune limited to the following....
1. I have what I believe is the proper MAF curve for my 2003 90MM LMAF loaded now.
2. I grabbed a 42# injector template off this site and loaded it.
Doesn't run a lot different with changes. It is pig rich and runs pretty random to 3K. Some ignition miss out the pipes. Sounds pretty good on a 3K-5K rev. (Not under load, no way I could drive the car yet) Threw some fresh plugs in it and re-verified base timing best I could with an engine that won't idle. Will try to datalog in BE now that I have the help files working. Only thing that alarms me from CALEDIT datalog is the advance seems way high. 50ish degrees. What should I be logging to make sure I am getting true advance?
thanks
Dewayne
Dewayne 347_NA Base.bin
base 347 tune
(56 KiB) Downloaded 453 times
347Tune+LMAF90-MEASURED-42LBTEMPLATE.BEB
current tune
(127.69 KiB) Downloaded 453 times
txman
Post by txman » Wed Dec 19, 2012 6:43 pm
I know this is a old post. Do you have a adjustable fuel pressure regulator? If so what is your fuel pressure with vacuum off. I have mine set to 39 psi with the vacuum off.
What is your Air Fuel ratio?
1995 Mustang Gt 347 EDL 6037 heads, RPM intake, voodoo cam, 90MM LMAF, 42LB inj., 3.73, mac long tubes with flow masters 3 chamber & H-pipe, Moates Quarter horse Clint Garity Binary editor 2010, innovate LC-1 WB with DB-blue gauge.
StangD
Post by StangD » Thu Dec 20, 2012 1:12 am
txman wrote:I know this is a old post. Do you have a adjustable fuel pressure regulator? If so what is your fuel pressure with vacuum off. I have mine set to 39 psi with the vacuum off.
On the advice of decipha I ditched the fancy FPR and put a stock one back on. Definitely acts much better now. Regarding my original problems. I had a number of issues. Found a vacuum leak, and had to deal with some rocker to polylock interference. I changed out a number of components to get that resolved and am running pretty good now. Switched to a QH as well, and VERY glad I did.
Users browsing this forum: No registered users and 112 guests
