Can anyone tell me where I'll find the cal code in an EECV bin file ?
Dave
Re: Where is Ford Cal Code in a bin
I've only ever seen it in Aussie calibrations.
Hi Derek,
Thanks for the reply.
Yeah, I think you may well be right, I can't find it anywhere, which is a bit of a downer, because in the FDS system, FORD name the bin files CALxxxx, so if I knew which one was my stock EXIT bin, I could replace it with my modified bin and re flash using my FDS............
There are soooo many files on the FDS that comparing them to a stock bin would take years.
I guess I'll just have to fork out some more dosh and try to get the Mongoose up and running, but I'm not certain if it has FEPS, or even whether the European ECU's actually need FEPS to flash them ??
Regards Dave
Regards Dave
The FEPS is needed to reflash an eec-v regardless of its market.
OK, do you know which ECU pin it sends the voltage to, or is it down the pin 15 / 16 communication line ??
Because I can't see a separate one on the FORD TIS Wiring diagram ;)
Cheers Dave
Cheers Dave
It's always pin 13 of the OBD2 port.
Likewise, every EEC-V PCM That I have played with has had it on pin 13 of the PCM as well.
Ah, yes I see it on the wiring diagram now, pin 13 ECU to DLC,
Dave
Dave
Users browsing this forum: No registered users and 48 guests
