Calculation Tools
Collection of newbie questions and common tuning concepts
Locked
dingurt
AFR vs LAMBSE calculator
Post by dingurt » Wed Feb 19, 2014 2:54 pm
I wrote a small program to help when dialing in the MAF. Maybe you guys can get some use out of it as well. The source code is included, if you want to compile it yourself.
Simple to use, just type your LAMBSE and AFR you are getting, and it spits out the % difference and a multiplier to apply to the MAF table air flow.
AFR Tool.zip
(50.13 KiB) Downloaded 628 times
1991 Mustang 5.0 - stock short block - stock T5 - 3.73 gear - Vortech V1 S-Trim - TF Track Heat heads & intake - TF stage 1 cam - Pro-M 80mm MAF - 1-5/8 shorties - 70mm TB - MSD Digital 6 Plus - Steeda Tri-Ax - Innovate LC-1 - QH, BE, EA
dingurt
Idle Air calculator
Post by dingurt » Thu Feb 20, 2014 2:07 pm
Ok, here is the idle air tool as well. Could you change the title of this to something like calculating tools, or something to that effect? As with the AFR tool, this also contains the source.
Idle Air Tool.zip
(60.28 KiB) Downloaded 527 times
Locked
