cobraslayer95
Anyone live in south al or fl panhandle
Post by cobraslayer95 » Fri Sep 12, 2014 3:46 pm
Will pay for some hands on tutoring with binary editor and eec analyze r
1995 Mustang gt, Forged 347 stroker, Trick Flow track heat heads, Track heat intake,msd distributor,comp blower cam, Vortech s trim 8lb pulley, 4" power pipe, 255 lph pump, 42lb,t-5 trans,centerforce dual friction, billet steel flywheel,3:73 gears, 15/8 headers, x pipe, spintech mufflers, moates quarter horse, lc1 wideband
dwbro1
Re: Anyone live in south al or fl panhandle
Post by dwbro1 » Tue Feb 09, 2016 2:49 pm
Near Gulf Shores here if anyone else in the area let me know.
Moates QH | DLG-1 WBO2 & LMA-3 | B50 block | CHP 347 (8.5:1) | Canfield Stage 3 Heads | Cam (284/294) | 1.6 roller rockers | Hydraulic Lifters | Canton Oil pan | Kenne Bell 1.5L (5 lbs Boost) | GT40 Lower | 75mm TB | Pro-M 75mm | 36lb Injectors | EEC-Tuner | MSD 6AL | Aluminum Driveshaft | 373:1 Gears | 9mm wires | Aero Fuel Pump (300 lph) | McLeod RST Clutch | Tremec TKO 500 | QuickTime Bellhousing | Wilwood Brakes | KB AGS Level 5 | Koni Reds | CC Plates | Springs | Flaming River steering shaft
