HI Guys
I did my research here and i see a couple of people running into the same issue with BE not logging the MTX gauge properly. My issue is probably a toggle setting that is not checked or something simple. I just can't figure it out. Go figure… The gauge connects and i can log. My issue is on my dash, the AFR will read line 9.0-10.0 and nothing more. I know it worked for me last fall but now this is what i get. My display on the gauge is reading fine. I can take pictures of what i see if this will help. Thank you in advance fellas.
92bigredbeast
Innovative MTX not logging thru BE
92BIGREDBEAST
1992 Mustang GT
Edelbrock Performer intake, heads, 70mmTB. E303,MSD dizzy,coil,6al,MoatesQH,BinaryEditor,Zeitronix ZT-2 w/ZR2 guage,Flex-a-lite 185, Vortech S-Trim 3.33/6.75 10-12psi,Anderson Power Pipe with bypass, BBK long tube, x pipe no cats to 3" Basanni,373 richmond,T5,Walboro 255,60lb injectors,P-Mas 95mm cal for 60lb....Lots more
1992 Mustang GT
Users browsing this forum: Bing [Bot] and 34 guests
