Datalogging Question
Am I correct in assuming that the highest load values in my datalog are indicating where my motor is producing peak power? If so, do peak load values indicate peak torque or peak HP?
_________________________________________________________________________
1989 Mustang 5.0 Coupe
Paxton Novi 1220SL Blower 6-8 lbs
CX Racing Power Pipe
Bosch 710N Bypass Valve
GT40P Heads w/ TFS Spring Kit
1.7 Crane Roller Rockers
Unported Explorer Intake
42lb FRPP F302 Injectors
HFP 255 lph Fuel Pump
65mm TB
90 MM Lightning Maf
E303 Cam
T5 Trans
3.27 Rear
MTX-L Wideband
A9P ECM w/ Moates QH
65mm TB
90 MM Lightning Maf
E303 Cam
T5 Trans
3.27 Rear
MTX-L Wideband
Re: Datalogging Question
torque
Peak mafv will indicate peak hp
I was just in atlanta this past tuesday and wednesday
I saw that, maybe next time we can meet up.
I'll attach a datalog later this evening and see if we agree on interpreting peak torque and hp.
65mm TB
90 MM Lightning Maf
E303 Cam
T5 Trans
3.27 Rear
MTX-L Wideband
65mm TB
90 MM Lightning Maf
E303 Cam
T5 Trans
3.27 Rear
MTX-L Wideband
Here is my most recent datalog with wot pass.
Please review and advise as to where you see peak power (torque/hp) being made.
65mm TB
90 MM Lightning Maf
E303 Cam
T5 Trans
3.27 Rear
MTX-L Wideband
65mm TB
90 MM Lightning Maf
E303 Cam
T5 Trans
3.27 Rear
MTX-L Wideband
