Looking up a 2D table; How to recognize the code
I've said in a another thread that you can rely on finding routines to look up 1D functions and 2D tables, and that they will usually have inline parameters.
They don't have to; many EEC-V bins pass parameters in registers.
So all ECUs need to look up valies in 2D and 1D data structures. Ford ECU folklore calls the 1D structure a function and the 2D one a table.
Ford in particular always uses 2 lookups of 1D functions prior to and whenever it looks up a 2D table.
This allows a smaller table that is more "precise" in some smaller regions, than a larger table that is precise everywhere. So it saves space.
However 1D lookups are also done not for 2D lookups. The airflow correction structure for a MAF system is a 1D lookup, and the airflow correction structure for a Speed Density system is a 2D lookup. That is the primary reason why SD calibration is a little bit harder. (it's not as hard as its made out to be).
All these lookups do the math for interpolation.
If your 1D lookup has 2 input values of 2 and 6 and corresponding output values of 50 and 30, and your input is 3, then what is your output?
it's 45.
But we need to know that math for that so we can recognize the code that does it.
Who wants to explain the math. I'm going on coffee break! :-)
Michael
it's 45.
Michael
Re: Looking up a 2D table; How to recognize the code
I'm not going to post the answer, but as I'm inclined to give a little clue, I will say the way the the Ford code INTERPOLATES (look that up, it's a clue) on a 2D lookup (often called a table) and their use of non-linear values is actually very clever. No not in an obfuscated way, but simple, clever, and mathematically neat.
So far I've only found that one 2D method in all the bins I've looked at, so it's easy to spot. Sure there are a few twiddles around it, but the core code stays very much the same.
The 1D (function) lookup uses a simple interpolation too, and similarly the method hasn't changed much ever since the very oldest bins I've seen.
Michael can argue, but I think (must double check) that the later bins have more accurate ROLAV maths, but again use same core algorithm
My intent in starting this thread is so that people can identify the function and table lookup code with great accuracy.
To do this, we need to understand the code, and to do that we want to understand the math that the code is trying to implement.
It's pretty simple math, but without it, people would be left guessing at what code they are looking at.
And we're doing all this because many of you good and curious people have asked how you know how many parameters might be inline.
So I'm hoping for another volunteer to explain the math for interpolation, perhaps using my example, and then together we can go over what code to do that would look like.
Michael
Michael
Thank you for the detailed background information. Probably need to work through an example to see how precision and space trade off.mpaton wrote: This allows a smaller table that is more "precise" in some smaller regions, than a larger table that is precise everywhere. So it saves space.
mpaton wrote:The airflow correction structure for a MAF system is a 1D lookup, and the airflow correction structure for a Speed Density system is a 2D lookup.
MAF volt row to get Mass of air from MAF Transfer function. SD needs MAP frequency row to get pressure and ACT Volt row to get temperature, then take pressure and temperature results to look up air mass table.
6-2=4 the difference in the input rangempaton wrote: If your 1D lookup has 2 input values of 2 and 6 and corresponding output values of 50 and 30, and your input is 3, then what is your output?
it's 45.
50-30=20 the difference in the output range
20/4=5 per increment of output range
3-2=1 difference between present value of the input and one end of the input range
50-5=45 so working from the same end of the range, deduct the output range increment for 1 increment
50-(3-2)/(6-2)*(50-30)=45
Now it just needs to be put together as a formula that can be coded with 8061 opcodes.
I'll have double black with two please, that should jump start the head :)mpaton wrote: Who wants to explain the math. I'm going on coffee break! :-)
Michael
INTERPOLATION turns up results in the LHBH strategy document.tvrfan wrote:INTERPOLATES (look that up, it's a clue)
Some reading to do to see how my way compares to Ford's best.
The SD correction table is actually N,MAPPA if i recall correctly. You can read about it in the LHBH doc. Absolute ACT is important, and in the equation, but it's not part of ford's correction table.jsa wrote:mpaton wrote:The airflow correction structure for a MAF system is a 1D lookup, and the airflow correction structure for a Speed Density system is a 2D lookup.
Thanks Johnjsa wrote:6-2=4 the difference in the input rangempaton wrote: If your 1D lookup has 2 input values of 2 and 6 and corresponding output values of 50 and 30, and your input is 3, then what is your output?
it's 45.
And of course when we get to the code, it's from the old days when a byte saved was worth something, so clever assembly code that was smaller was valued.
Michael
LHBH talks about 4 point interpolation, so that would be for a 2D table ?
Probably what tvrfan was hinting at;
viewtopic.php?f=8&t=19610&hilit=interpolates
Sailorbob's example
viewtopic.php?p=47551#p47551
lower output + (((upper output - lower output) x (value in - lower input)) / (upper input - lower input)) = value out
50+(((30-50)*(3-2))/(6-2))=45
Sailorbob's example
In case it helps anyone, when I first looked at this (the code), I actually visualised in my head a spreadsheet like or matrix structure, with 11 X 11 (or whatever) cells, or dots, where the exact input values intersect.
Then when the two input values each fall between their data points, and where the answer would be as a point between 4 fixed ones.
That worked for me, and then I understood the code workings immediately....and why you only need 3 calls to the interpolation routine.
Just my 2c worth...
Just my 2c worth...
I agree with both of you.
Michael
Michael
most all the lookup interpolation routines in henrys code uses 34 36 38 or 3c as inputs in all that ive looked at
the function address is then incremented by a byte or word to find the less than value compared by the input
once it finds it those 4 values 2x x and 2x y are interpolated
Its usually pretty easy to find since there arent many places an L is incremented [xx+4] followed by a compare loop
So now ironman has "fixed" all the calls to the 1D lookups, what are they doing?
Here's the first call
3F3B EF6006 call L459E
3F3E 8E00 word $008E
3F40 B600 word $00B6
or maybe we have
3F3E 8E byte $8E
3F3F 00 byte $00
3F40 B6 byte $B6
3F41 00 byte $00
depending on whether we used word or byte for the directives. That didn't matter when we did it, because our goal was just to disassemble code as code. Now we're going to look at the data.
So what's the code at $459E look like? We know it's going to look up a 1D table (single input, single output),we know there will be interpolation code. So there are 2 inputs to this routine, and one output. The inputs are the input to the table, or more likely the address of the input, and also the table, or more likely the address of the table.
So the code at $459E is
So we see that after 45A9, it's going to execute the instructions at
45A9
45AB
45AE
Ironman, or jsa, would you like to explain what those 3 instructions do? you'll need to have downloaded the 8061 instruction guide.
Michael
or maybe we have
3F3E 8E byte $8E
3F3F 00 byte $00
3F40 B6 byte $B6
3F41 00 byte $00
459E 91209D L459E orb REG_9D,#$20 ; set REG_9D,BIT_05
45A1 2006 sjmp L45A9
45A3 91209D orb REG_9D,#$20 ; set REG_9D,BIT_05
45A6 91109D orb REG_9D,#$10 ; set REG_9D,BIT_04
45A9 CC36 L45A9 popw REG_36
45AB B23732 ldb REG_32,[REG_36]+
45AE B23733 ldb REG_33,[REG_36]+
45B1 AC3334 ldzbw REG_34,REG_33
45B4 710F33 an2b REG_33,#$0F ; clr REG_33,BIT_04 Edit
; ; clr REG_33,BIT_05
; ; clr REG_33,BIT_06
; ; clr REG_33,BIT_07
45B7 080434 shrw REG_34,#$04
45BA 6735F00032 ad2w REG_32,$00F0[REG_34]
45BF B23734 ldb REG_34,[REG_36]+
45C2 B23735 ldb REG_35,[REG_36]+
45C5 C836 pushw REG_36
45C7 B23434 ldb REG_34,[REG_34]
45CA 9B320234 L45CA cmpb REG_34,$02[REG_32]
45CE 3D9D04 jb REG_9D,BIT_05,L45D5
45D1 DB0A jc L45DD
45D3 2002 sjmp L45D7
45D5 D606 L45D5 jge L45DD
45D7 65020032 L45D7 ad2w REG_32,#$0002
45DB 27ED sjmp L45CA
45DD 71DF9D L45DD an2b REG_9D,#$DF ; clr REG_9D,BIT_05
45E0 B23336 ldb REG_36,[REG_32]+
45E3 B23338 ldb REG_38,[REG_32]+
45E6 7A3236 sb2b REG_36,[REG_32]
45E9 7A3334 sb2b REG_34,[REG_32]+
45EC 7A3238 sb2b REG_38,[REG_32]
45EF 3C9D04 jb REG_9D,BIT_04,L45F6
45F2 DB09 jc L45FD
45F4 2002 sjmp L45F8
45F6 D605 L45F6 jge L45FD
45F8 91209D L45F8 orb REG_9D,#$20 ; set REG_9D,BIT_05
45FB 1338 negb REG_38
45FD 7C3438 L45FD ml2b REG_38,REG_34
4600 9C3638 divb REG_38,REG_36
4603 359D02 jnb REG_9D,BIT_05,L4608
4606 1338 negb REG_38
4608 763238 L4608 ad2b REG_38,[REG_32]
460B 1139 clrb REG_39
460D 71DF9D an2b REG_9D,#$DF ; clr REG_9D,BIT_05
4610 71EF9D an2b REG_9D,#$EF ; clr REG_9D,BIT_04
4613 F0 ret
45A9
45AB
45AE
Michael
Ok, it will be a couple days until I can do it justice.
ironmanisanemic
Its going to be a while before i will be able to get to this. I have a bunch of stuff at work that i just got slammed with, plus all hell just broke out in my house. I might be having to do a trans rebuild on my wifes car and dont have the cash at the moment so i might have to take a second job. But i will try to work on this slowly when i have time.mpaton wrote:So now ironman has "fixed" all the calls to the 1D lookups, what are they doing?
or maybe we have
3F3E 8E byte $8E
3F3F 00 byte $00
3F40 B6 byte $B6
3F41 00 byte $00
So we see that after 45A9, it's going to execute the instructions atCode: Select all
459E 91209D L459E orb REG_9D,#$20 ; set REG_9D,BIT_05 45A1 2006 sjmp L45A9 45A3 91209D orb REG_9D,#$20 ; set REG_9D,BIT_05 45A6 91109D orb REG_9D,#$10 ; set REG_9D,BIT_04 45A9 CC36 L45A9 popw REG_36 45AB B23732 ldb REG_32,[REG_36]+ 45AE B23733 ldb REG_33,[REG_36]+ 45B1 AC3334 ldzbw REG_34,REG_33 45B4 710F33 an2b REG_33,#$0F ; clr REG_33,BIT_04 Edit ; ; clr REG_33,BIT_05 ; ; clr REG_33,BIT_06 ; ; clr REG_33,BIT_07 45B7 080434 shrw REG_34,#$04 45BA 6735F00032 ad2w REG_32,$00F0[REG_34] 45BF B23734 ldb REG_34,[REG_36]+ 45C2 B23735 ldb REG_35,[REG_36]+ 45C5 C836 pushw REG_36 45C7 B23434 ldb REG_34,[REG_34] 45CA 9B320234 L45CA cmpb REG_34,$02[REG_32] 45CE 3D9D04 jb REG_9D,BIT_05,L45D5 45D1 DB0A jc L45DD 45D3 2002 sjmp L45D7 45D5 D606 L45D5 jge L45DD 45D7 65020032 L45D7 ad2w REG_32,#$0002 45DB 27ED sjmp L45CA 45DD 71DF9D L45DD an2b REG_9D,#$DF ; clr REG_9D,BIT_05 45E0 B23336 ldb REG_36,[REG_32]+ 45E3 B23338 ldb REG_38,[REG_32]+ 45E6 7A3236 sb2b REG_36,[REG_32] 45E9 7A3334 sb2b REG_34,[REG_32]+ 45EC 7A3238 sb2b REG_38,[REG_32] 45EF 3C9D04 jb REG_9D,BIT_04,L45F6 45F2 DB09 jc L45FD 45F4 2002 sjmp L45F8 45F6 D605 L45F6 jge L45FD 45F8 91209D L45F8 orb REG_9D,#$20 ; set REG_9D,BIT_05 45FB 1338 negb REG_38 45FD 7C3438 L45FD ml2b REG_38,REG_34 4600 9C3638 divb REG_38,REG_36 4603 359D02 jnb REG_9D,BIT_05,L4608 4606 1338 negb REG_38 4608 763238 L4608 ad2b REG_38,[REG_32] 460B 1139 clrb REG_39 460D 71DF9D an2b REG_9D,#$DF ; clr REG_9D,BIT_05 4610 71EF9D an2b REG_9D,#$EF ; clr REG_9D,BIT_04 4613 F0 ret
45A9
45AB
45AE
Michael
Do you have a link to the 8061 instruction guide? I dont believe i have it already.
Thank you
1989 Ford Bronco:
1995 Ford Mustang GT
Thank you
was this just not restored after the board crash a few years ago, or is it gone for good?
Michael
If it was between April and September of 2014, then yeah, it was lost. I'm just glad I had a backup at all since none of Jon's backups were viable.
Could you put up a link for ironman please?
Is it this or something better ?
Here is a M$ doc one I got from somewhere a long time ago 8061 and 8065.
Page 45 on, of linked book below, gives some decent explanation of addressing modes.
http://bitsavers.informatik.uni-stuttga ... ndbook.pdf
