Quarter Horse Anti-lag setup
Have a suggestion or a submission for a FAQ or Tech Doc? Post it here...
95GTSpeedDemon
Post by 95GTSpeedDemon » Wed Dec 16, 2015 10:29 pm
Anti-Lag tune switching will need the pins soldered to the QH. These are the instructions from Moates. I have extra female connectors to solder on and male wiring connectors. When I run out, contact Moates.
http://www.moates.net/documentation.php ... tion_id=78
Its only active when the arming switch is on, clutch is pushed in and its in 1st gear.
Setup tune as followed:
(CBAZA) Change all 3 timing tables, & MBT table set to 55 (disabled)
End result:
95GTSpeedDemon
Re: Quarter Horse Anti-lag setup
Post by 95GTSpeedDemon » Thu Sep 07, 2017 8:24 pm
due to photobucket being useless...
male connector_zps8jxm1tjt.JPG (195.94 KiB) Viewed 4755 times
clutch switch_zpsyfif1xxn.JPG (120.5 KiB) Viewed 4755 times
circuit diagram_zpsx2tjlgad.PNG (431.37 KiB) Viewed 4755 times
change overview_zpsaxrwnmio.PNG (18.88 KiB) Viewed 4755 times
arming switch_zpsmept4th2.JPG (183.34 KiB) Viewed 4755 times
95GTSpeedDemon
Post by 95GTSpeedDemon » Thu Sep 07, 2017 8:26 pm
#2
timing table_zps6svb6trz.PNG (29.43 KiB) Viewed 4754 times
Shifter switch_zpszdghokur.JPG (205.1 KiB) Viewed 4754 times
shifter 2_zpset8sm8y6.JPG (244.31 KiB) Viewed 4754 times
Post by decipha » Sat Sep 09, 2017 5:15 am
i wrote a two step code for cbaza two years ago back in 15, instead of doing all that you can just enable it in the tune and it will be active when your foot is on the brake and your not moving, vehicle speed = 0, as soon as u take your foot of the brake or the car moves it disables it
post your bin and ill patch it for you if your interested
95GTSpeedDemon
Post by 95GTSpeedDemon » Sat Sep 09, 2017 7:37 am
that would be great.
17psi v83.BIN
(56 KiB) Downloaded 120 times
306TTcobra
Post by 306TTcobra » Sat Jun 23, 2018 4:35 pm
Hi can you post the bin for anti lag and 2 step
