mustang5oh
anyone in uk using tweecer for there mustang h.o?
need help understanding this software, I would like to do that trick with timing lockout but on the tweecer. timing lockout was done before I had issues with the car and the garage reset it all back to stock timing etc
94 5.0 ho T4MO 16 psi vortech v2, stock heads, felpro steel gasket, t rex pump, vortech FMU 19#s injectors
Re: anyone in uk using tweecer for there mustang h.o?
what is timing lock out? you mean remove the spout and set the base timing to a specific point?
not only is that not wise, not efficient, not safe, and not beneficial in any way, its just down right useless and I highly advise against doing that
if your having trouble getting started just toss the a9l2 in it, you'll be significantly better off
