Had a quick gander.
What software do you plan to use, tunerpro or BE ?
Couple of the functions might be temps, 7F and 80 being clues. Some of the tables might be load related. Didn't see MAF transfer like function.
Run the bill lawrence dissassembler that mike paton posted it will break out code different to SAD.
Re: Ford Probe 3.0l
Re: Ford Probe 3.0l
Ah, no MAF to find then.
You likely need the version of BL that Mike Paton posted recently as Mike fixed an issue with file size.
http://eectuning.org/forums/viewtopic.p ... bl#p123487
http://eectuning.org/forums/download/file.php?id=3956
From the zip, put the DIR file together with BL and your BIN. The lst is the output from BL.
Open the dos box where you have the 3 files. In Win7 Shift+Right click then choose Open Command Window Here.
Example of dos box use
C:\your folder\your subfolder\bl.exe Dave5
Yeah, suit yourself on BE or TP, depending on what you go with grab an open definition file for either and look at how they are structured and compare to the tables and functions that SAD finds.
Re: Ford Probe 3.0l
excuse my ignorance im trying to follow along but i don't understand what your saying
what is sim1 ? is that a catch code binary file? perhaps sim1.bin?
are you saying the sim1 was setup to run on a9l?
your stock bin is for a v6 speed density ecu? is that sim1 ?
Re: Ford Probe 3.0l
Where did you get this "Sim1" program?
Re: Ford Probe 3.0l
I dont understand what your trying to achieve with the simulator
it seems pretty useless to me
Re: Ford Probe 3.0l
voltage offset
high slope
Low slope
Breakpoint
min pw clip (91+ strats)
cranking pw
high slope
Low slope
Breakpoint
cranking pw
Users browsing this forum: No registered users and 41 guests
