tvsn94
big fuel pump problems
Post by tvsn94 » Wed May 04, 2016 11:54 am
has anybody experienced what appears to be a leaning out through the curve after changing to a big aeromotive 340L in tank pump? it seams to appear after an hour of driving. idle pressure is still 38lbs.
Re: big fuel pump problems
Post by decipha » Wed May 04, 2016 1:01 pm
idle pressure shouldnt fluctuate
if nothing changed but the pump i would suspect the fuel is getting heated
you seem to have a basic setup, why not use a 255 pump?
tvsn94
Post by tvsn94 » Wed May 04, 2016 1:07 pm
I ran out of duty cycle with the 255 walbro that i had, I am doing some TEST to determine if its the pump heating the fuel.
Paulie
Post by Paulie » Wed May 04, 2016 2:48 pm
I have seen reports where the aeromotive 340L pump draws so much current it starts melting wiring and connectors. Did you upgrade your wiring?
I am also surprised a 255L pump was not enough for your combo.
tvsn94
Post by tvsn94 » Wed May 04, 2016 3:50 pm
oh yea, i have a 30amp separate relay to prevent any extra trouble. anybody got an old race fuel lines and rails laying around ??
