I would like to be able to log my Autometer AFR in BE. It appears that I should be able to use the DataQ 145 to do this but I need a little guidance.
I have the Autometer hooked up to the DataQ and the USB hooked to the computer but I'm not seeing how to add that signal to the dashboard and see the readings on my computer.
I found a few threads mentioning using these pieces but no responses or one response that kind of went nowhere.
Thanks.
Autometer AFR and DataQ 145 with Quarterhorse?
1989 Ford Country Squire - 347 Stroker, Quarterhorse tune
Re: Autometer AFR and DataQ 145 with Quarterhorse?
get in touch with Clint Garrity or Adam Marrer
you have to pay extra for the dataq license for use with BE, make sure if you hadnt already that you have it
go to the hardware tab on BE and make sure the dataq is enabled
go to the dataq transfer and select which every input your wideband is on and insert the voltage to lambda transfer, you can assign the input a name to show up in your datalogs as there too
