I purchased a throttle body that is setup for a GM style IAC. Is there a manufacture that makes a adaptor or IAC that will allow me to use a PWM IAC like on Fords?
I considered modifying the throttle body and using a remote style setup and running a ford IAC.
bindingposts
Re: Chevy style TPI for Ford ECU w/ QH?
there is a microsquirt product to convert pwm signal to stepper motor
http://www.efisource.com/shop/microsqui ... r-adapter/
62 falcon 4.6dohc czajl z4h0
85capri 2013 302, boss intake ms3
60 f100 427w e4od ahacb
83capri ms3 384w s475 e85 mid 9's
02 f350 7.3
02 f350 7.3
i always use the 99-04 IACs on those setups and remote mount it with vac hoses no problem, just make sure it draws after the maf
