Valve blowby at less then 10k miles
My 351w has around 8k miles on it, runs pretty decent but seemed to have lost some power so I decided to do a leak-down test. It has pretty severe blowby on the intake valves (i have all the rockers/pushrods removed) and I cant really understand why. When I first built the engine, it had none. The heads are N351's that i had assembled by a local, pretty reputable, machine shop. The valves I'm running are the Ford stainless valves that are recommended to be used with these heads. Why would the valves wear so bad so quick? Would it maybe be better once the engine was warmed up? At this point I'm ready to pull the heads and have them reworked.
1992 f150 4x4 built E4OD, 351w, 351N ford sportsman heads, edlebrock truck intake, bbk dual 61mm throttle body, comp cam (.544 lift, 270/276 duration), 30lb injectors, 90MM lightning maf, full length headers, K&N cold air.
Re: Valve blowby at less then 10k miles
most prob you have the wrong rockers, the n351s require an offset rocker
I havent seen or heard of them heads in over 10 years amazing
I have the offset rockers. But both the rockers and pushrods are removed. So both valves should remain fully shut during the leakdown test. I know the heads are oddball, but I wanted to stick with steel heads and I really like the n351s.
Valve clearance / bent valves ?
Users browsing this forum: No registered users and 34 guests
