93LX5OH
Working on a base tune for my 93
Post by 93LX5OH » Wed Jul 27, 2016 7:13 pm
Hello Everyone,
So i will start out by saying this is the first car i have tried to tune myself. Currently i have the car running with an A9L along with an out of date chip that came with the car. The car gets around ok, but really i am just putting miles on the build at the moment and i am getting far too lean for safety (under load). I also have a Quaterhorse currently installed on a spare A9P with binary editor that i have been playing around with, but have not plugged her in yet. I will try and give as much relative info about my build as possible and upload the the calibration i have been working on. If i could get some input on what i should change before swapping my A9P into the vehicle i would appreciate it.
1993 LX 5 Speed, Stock bottom end, GT40P heads, B303 Camshaft, 1.7 RR, GT40 Tubular Intake, Ported Lower, 1" aluminum intake spacer, 70mm Mass Air, 24lb injectors , 76mm MAF, Fender CAI with cone filter, BBK long tubes, off road H pipe, SLP loadmouths, Flowmaster stainless axleback. I have all serpentine belt loads deleted except for the Alt (Electric water pump, manual steering gear, tensioner pulley delete, smog delete etc). I have an Innovate MTX-L Wideband that i can currently log my AFR with logworks, but plan on using the EGR wire to log it through Binary Editor.
Thanks for your time,
V/R
Adam P.
V/R, Piper
1993 LX Vert. A9L, Moates Quarterhorse, Binary Editor, Innovate Motorsports MTX-L, Stock Bottom End, Ported GT40P Heads, TF Valve Spings, B303, 1.7 Rockers, GT40 Tubular Upper w/ Ported Lower Intake and 1" Riser, 70mm TB, 76mm MAF, SVE CAI, 24lb Inj, BBK Longtubes and Off Road H-Pipe, SLP Loudmouths, Flowmaster Axleback, 3.73 Gears, T-5 w/ Pro 5.0 Short Shift, 275/40-17
1969 GT Fastback, 351W, C6 (Numbers Matching 56k Miles)
2014 GT Convertible, Coyote (Grabber Blue, Track Pack)
85GT
Re: Working on a base tune for my 93
Post by 85GT » Wed Jul 27, 2016 8:03 pm
With a Quarterhorse, you can also load a A9L bin onto your A9P if you're more comfortable with that one.
93LX5OH
Post by 93LX5OH » Wed Jul 27, 2016 11:56 pm
What strategy would you use? GUFB?
V/R, Piper
Paulie
Post by Paulie » Thu Jul 28, 2016 2:29 pm
93LX5OH wrote:What strategy would you use? GUFB?
Yes GUFB
