I have the Innovate DLG-1 and LMA-3 in my Mustang with BE.
My DLG-1 WBs are data logging just fine in BE but nothing else. :( I know it has to be how they are setup in BE just a little confusing to me. Here is what I have
1. My WBs are fine logging into BE on channels 0 and 1.
2. I have RPM in channel 3 which isn't recording
3. Channel 4 is lateral G (nothing logging)
4. channel 5 I have EGT sensor in passenger side header that won't record.
5. channel 7 is forward G
6. channel 6 is MAP sensor ( I have inline with Boost guage nada recording)
7. channel 8 NONE
Any help would be appreciated. I've read over the BE instructions and cannot quite figure it out
Innovate LMA-3 Sensor setup Binary Editor
Moates QH | DLG-1 WBO2 & LMA-3 | B50 block | CHP 347 (8.5:1) | Canfield Stage 3 Heads | Cam (284/294) | 1.6 roller rockers | Hydraulic Lifters | Canton Oil pan | Kenne Bell 1.5L (5 lbs Boost) | GT40 Lower | 75mm TB | Pro-M 75mm | 36lb Injectors | EEC-Tuner | MSD 6AL | Aluminum Driveshaft | 373:1 Gears | 9mm wires | Aero Fuel Pump (300 lph) | McLeod RST Clutch | Tremec TKO 500 | QuickTime Bellhousing | Wilwood Brakes | KB AGS Level 5 | Koni Reds | CC Plates | Springs | Flaming River steering shaft
Users browsing this forum: No registered users and 19 guests
