Looking for Bosch injector data
Where can I find the data for 30 lb Bosch Type III injectors? They didn't come with anything. Thanks
Re: Looking for Bosch injector data
do you have a part number or color? how bout a stock application to cross reference?
I plan on adding about 25 sets of oddball injector info to my injector reference data page with values I came up with on various setups I've done over the years
im sure ive done the bosch 30s if you have more details on them
I purchased them at LMR. Here is a pic from their website and maybe you can make out the number on the side. Im going to try and call them too.
The number looks like 0 280 155 881. I can't quite make out the last 3 numbers which are actually the most important. A quick Google search doesn't find that number but it seems the more popularly searched number is 0 280 155 931 however they appear to be 25lb/hr gray injectors. So I doubt that's what this is either. There's no indication on Google they were ever orange. So I don't know...
Just eyeballing, the injectors look like 19lb EV6 injectors with EV1 connectors which were standard equipment on a number of Ford applications like 96-97 Ford Explorer 5.0L V8s as well as the 95-97 Ford Ranger 4.0L V6. Jeeps and a few other brands used them as well.
There are a LOT of Bosch numbers for the 19lb EV6 with EV1 connectors. I believe they were 0 280 155 XXX and 0 280 166 XXX. The different PNs differentiate differences in length, diameters on either the rail or intake end, plastic skirt styles, etc etc. Bosch injectors that came from Ford usually have a Ford PN stamped on them that follow standard Ford engineering number format making finding out what they are even easier.
I had heard that there was an orange 30lb Bosch injector that was easily confused with the stock 19lb orange ones, and this may be them...but I've never actually seen them for myself. You may have found them.
They were ordered from Late Model Restoration and are stated as Bosch Type III EV1 30 lb injectors. "Brown" maybe? The last three numbers look like 881.
I was able to read one in the car. The last digits are 831.
They are on this list. 0280155831. What does all of that mean regarding slopes and things?
http://www.gomog.com/allmorgan/InjectorRatesBosch.html
That list lacks the information you are looking for. About all you get from that list is high slope. You are still missing low slope, breakpoint and injector comp. vs. battery voltage.5liter95 wrote:They are on this list. 0280155831. What does all of that mean regarding slopes and things?
Users browsing this forum: Google [Bot] and 21 guests
