GT40 Lowers and KB Blowers
Moderators: cgrey8, EDS50, Jon 94GT, 2Shaker, tmoss
Locked
tmoss
Post by tmoss » Mon Jun 05, 2017 8:23 am
Seems the use of Explorer lowers to mount Kenne Bell blowers has been hit and miss, some people have good luck and others wind up with about 1/8" misalignment on the belt and have issues. I had some lowers and took some measurements compared to a Cobra lower and found I had one of the ones that would be an issue - here is an article with pictures on what I found. I added a note in the text indicating the 1/8" thickness of my square which was not added to the lengths measured so that people could see the dimensions on the edge of the ruler. If anyone wants to measure a lower they have to check it, add the 1/8" thickness of my square to the dimensions in the picture text and then subtract the thickness of whatever you might use in place of the square for measurement.
GT40 Lower Intakes and KB Blowers.pdf
(588.25 KiB) Downloaded 205 times
Locked
Users browsing this forum: No registered users and 0 guests
