tvsn94
86 to 96 conversion pinout
Post by tvsn94 » Thu Jul 27, 2017 4:41 pm
I am doing a 1986 mustang to 1996 f150 pcm conversion. this i know has been done many times and i have a few questions about.
such as, is it necessary to provide power to all pins in the 96 pcm ? how about all grounds? does the pin (#49 listed as CKP ) same as PIP?
any words of wisdom please???
LeadHead
Re: 86 to 96 conversion pinout
Post by LeadHead » Thu Jul 27, 2017 7:12 pm
I have literally never heard of a single person doing an EEC-V conversion on a Foxbody before. I really don't see what you expect to gain with this conversion.
All power and ground pins need to be hooked up. CKP is not the same as PIP. CKP for the crank sensor, which your engine doesn't have.
tvsn94
Post by tvsn94 » Fri Jul 28, 2017 8:12 am
the advantage is
better faster processor, on board data logging , and a future of unlimited upgrades, simple programmer hook ups, ( no flakey QH and chips), and its 10 years tech-know newer. in will be MAF of course and that opens lots of doors over SD
Post by EDS50 » Wed Aug 02, 2017 11:19 am
tvsn94 wrote: ↑Fri Jul 28, 2017 8:12 am the advantage is
How do you plan on datalogging and changing the tune with your new ecm?
Users browsing this forum: No registered users and 32 guests
