PhillipP
BE & DATAQ-1100 - Failure to Communicate
Post by PhillipP » Thu Aug 24, 2017 7:05 pm
Hello,
Need some help setting up BE to datalog with OBDII and a Dataq DI-1100. Using dongle hardware license.
Symptoms: dataq menu is lit, indicating license is good; commanding data log start causes a brief cycle in the status bar, from idle to poll starting, to idle again. Duration is less than 10 seconds. No .csv's are written. If dataq hardware is disabled BE will data log as normal.
Corrective actions attempted thus far:
- verified signal from dataq via dataq software
- uninstalled all dataq software and drivers
- re-installed dataq software and drivers
- reconfigured transfer function
- contacted Clint Garrity
Suggestions?
Phillip P SCCA-SCR, Region #79
2006 Ford Focus - DD, 5 gears of blue fury
1985 Chevy C10 - Expendable work truck, 383 cid of carb'd fun
2001 Ford Mustang - My eec-v dillema
PCM: TBX3/RTAI - Flashed to: CHB3/RTA1 - Cal Tool: BE & J2354 -Ford slot maf, 96 mm, ID1000's, NTK AFRM Gen 1
4.3 stroker v6 - eaton m112 - astro 5 speed - 3.27 rear - LOTS of suspension and brakes work
PhillipP
Re: BE & DATAQ-1100 - Failure to Communicate
Post by PhillipP » Fri Aug 25, 2017 5:48 pm
I noted the status bar at the bottom of BE isn't indicating the Dataq is connected. The status history does show OBDII status changes as I enable/disable it under the hardware menu. Could that be a clue or normal when using Dataqs?
LeadHead
Post by LeadHead » Mon Aug 28, 2017 6:49 pm
Clint didn't offer any insight?
PhillipP
Post by PhillipP » Mon Aug 28, 2017 8:15 pm
Clint has been largely unavailable for the last few weeks. His initial recommendations are part of my attempted corrective actions.
Post by decipha » Sat Sep 09, 2017 5:53 am
make sure nothing else is checked to log along side the dataq as well, such as the innovate wideband and moates are unchecked to not log
clint has been really busy lately
PhillipP
Post by PhillipP » Thu Sep 28, 2017 10:13 am
Following up, slightly overdue. Clint and I did get in touch. He provided a beta version that does work with the new dataq. I believe a new release is on the way that incorporates the changes.
I must say the dataq is way nicer than the sct kit I had been using.
Post by decipha » Tue Oct 03, 2017 9:22 pm
have u tried the moates superlogger? it basically replaces the dataq and interfaces right into the QH
PhillipP
Post by PhillipP » Wed Oct 04, 2017 7:43 am
I'm working via the J2354 interface, not the J3. Flash cable from drew tech via core tuning. The QH+SL has appeal, but I'm already invested, and its now working smoothly.
